Old 01-24-2013, 07:10 PM   #1
2003silver330i
My Ride: 03 BMW 330i
Cold engine misfires in three cylinders
Everyday I continue to get three cylinder misfires. It is always three cylinders. Today it was cylinder 1, 2, 3. Yesterday the misfires were 2, 4, 6. The day before it was 2, 4, 5 and so on. This has been going on for over a month now. Before it would be one random cylinder misfire but the problem has gotten worse. The wife drive the car daily and it is driving her nuts and I get to hear about almost daily. The car has 143K miles on it and these are the things that have been replaced in the last ten months:
Fuel Pump
Fuel Filter
Throttle Body
DISA
Exhaust CPS
Spark Plugs
Valve Cover
Valve Cover Gasket
All 6 Ignition Coils
Cleaned ICV several times
Clean MAF several times
2003silver330i is offline   Reply With Quote
Old 01-24-2013, 07:22 PM   #2
2003silver330i
Disregard. Wife just got home and said there were no misfires today so I guess I fixed the problem last night with some miracle juice. Will continue to monitor.
Old 01-24-2013, 09:20 PM   #3
zhenkaaaM3
My Ride: Fst'r then your e46
The MAF would cause something like that. Cleaning it doesnt always do the job.
In my case, I had 6 misfires due to a slit on my intake boot. Crazy aint it?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 01-24-2013, 09:42 PM   #4
jfoj
My Ride: 330CiC, M5, X5
You need a scan tool that will read real time data.
You need to look at the fuel trims, temps and MAF readings.
If you have a Droid phone or tablet, $5 Torque App and a $15 OBD to Bluetooth Adapter. If not, see below:
You need to read these links -
http://forum.e46fanatics.com/showthr...ghlight=report
http://forum.e46fanatics.com/showthread.php?t=967204
Old 01-24-2013, 11:16 PM   #5
2003silver330i
I don't have an android. I was thinking maybe the CCV is toast or MAF. The idle feels low and fluctuates like it is about to die for about 10-15 seconds on a warm engine when starting it up.
Old 01-24-2013, 11:22 PM   #6
jfoj
Suggest you get the software in the 2nd link I provided if you do not have a Droid.
The price is up $2 from a few days ago, still under $25 at this moment.
