E46 Convertible
Old 01-24-2013, 09:09 PM   #1
dreamteam1000000
My Ride: 2003 x5 (e53)
Guys I need your help temp problems
Ok so I have a 02 325ci and have been having issues with my temp going up and down, if I'm driving sometimes it will shoot up to hot then right back down to the middle when it was plugged up the coolant temp sensor came up as a code, so I had it replaced. Now since then my car in idle the temp will slowly rise. If te heat is on no problems really also when driving if the heat is off the temp goes a tad bit over the half. But again if heats on it's fine... I also had both hoses in the rear but the heater core changed because there was a hole. Then the mechanic said I needed a fan clutch, got that done and stilllll the same ****. Anyone have this issue or hear of it please help thanks
e46
dreamteam1000000 is offline   Reply With Quote
Old 01-24-2013, 11:44 PM   #2
dreamteam1000000
Bumpppp
e46
Old 01-25-2013, 09:46 AM   #3
dreamteam1000000
e46
Old 01-25-2013, 10:05 AM   #4
3coupe
My Ride: 330Ci
99.9% sure it's air in the coolant system. Your temp goes up when a pocket of air circulates and then drops back when coolant goes through. Bleed the coolant system. 10 minute job, 2 if yuor car is already warmed up.
The reason it's not getting hot when your heater is on is because the heater is "cooling" the engine slightly, and the thermostat is completely open (at least from what I've read) when the heater is on.
3coupe is offline   Reply With Quote
Old 01-25-2013, 10:41 AM   #5
dreamteam1000000
the shop did bleed the system there was a big air pocket in there but it could b that there is still some in you think?
e46
Old 01-25-2013, 10:48 AM   #6
3coupe
My Ride: 330Ci
Sounds like it. The bleeding procedure is posted on here. Defiantly worth a try since all it will cost is 10min of your time.
Old 01-25-2013, 11:07 AM   #7
dreamteam1000000
do you know the link for the bleeding pro
e46
Old 01-25-2013, 01:53 PM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
To me it also sounds like you still have air in the system. HERE is a link on how to bleed the E46 cooling system.
Old 01-25-2013, 01:57 PM   #9
dreamteam1000000
thanks will do
e46
Old 01-25-2013, 02:10 PM   #10
dreamteam1000000
i see u sell lights so you sell the lights for the license plate lol
e46
Old 01-25-2013, 02:11 PM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
For the E46? Ziza has LED plate bulbs (LINK)
Old 01-26-2013, 08:04 AM   #12
sgoetz628
My Ride: 2002 330 CiC
Get a new mechanic. Diagnosis didn't fit symptoms, since it happens when you're driving - air flow over radiator is just like when fan is running. Also, sounds like he didn't do a thorough job bleeding and was quick to recommend a more expensive fix.
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 01-26-2013, 09:46 AM   #13
dreamteam1000000
i agreee with you im looking for a new mechanic aswell lol
e46
Old 02-06-2013, 09:48 AM   #14
dreamteam1000000
bleeding the system didnt work
e46
Old 02-06-2013, 10:30 PM   #15
sgoetz628
Do you remember what your source was for that? Seems counter-intuitive to me. Heat is normally called for when the ambient temperature is low, which is when the radiator can take the most heat out of the coolant, also the heater is taking heat out of the coolant, so the coolant is likely to be cooler, hence the need for the thermostat to be partially closed. I'm sure that's a run-on sentence, but still, makes no sense to me.
