Engine & Performance
Old 01-25-2013, 11:06 PM   #1
slow330
My Ride: 330ci
ASA 9-10psi Pulley.
Like tittle states, am looking for a ASA
Tm12 supercharger pulley! 9-10psi
I know its along shot, but i thought i asked! Thank you....
slow330 is offline   Reply With Quote
Old 01-25-2013, 11:25 PM   #2
TrippinBimmer
My Ride: Just Fast!
Gl with find
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-26-2013, 11:24 AM   #3
xaviman
My Ride: Supercharged
Im in the same boat, looking for more boost! aready went thru 6 and 8psi
Screen shot 2014-01-25 at 12.36.33 PM by xaviman, on Flickr
Instagram: xaviman
xaviman is offline   Reply With Quote
Old 01-26-2013, 04:30 PM   #4
slow330
My Ride: 330ci
Correct me if am wrong!
But the 140mm pulley its 8psi
Correct!
Because i have a member selling me a pulley he claims 10psi and its 145mm!
Old 01-27-2013, 01:38 AM   #5
TrippinBimmer
My Ride: Just Fast!
Correct!
Smaller more boost bigger pulley less boost....
Alpine White M3
MaximumPSI Stage4
Old 01-27-2013, 09:20 AM   #6
slow330
My Ride: 330ci
Correct! Just wondering because he says he's pulley its 10psi 145mm
And he ran it on his 323ci
As far as i know engine size should not matter. O well!
On the other hand i have received and email stating 140mm its 6.5psi
For the ASA tm12 and not 8psi ??
Old 01-27-2013, 09:26 AM   #7
TrippinBimmer
My Ride: Just Fast!
To be honest. It's hard to tell how much boost the manifold will see as each motor (325, 328, 330) takes in different amount of air volume at a time. 325 motor might see 10psi but 328 will see 8.5-9 as its displacement is much bigger...
I would recommend going with -10mm to -15mm from what you have and go from there...
Alpine White M3
MaximumPSI Stage4
Old 01-27-2013, 10:33 AM   #8
xaviman
I emailed Samir last night, the 10psi pulley is 130mm, but they dont have it available and would have to be fabricated from scratch, they want $350 for the single pulley
Instagram: xaviman
Old 01-27-2013, 09:59 PM   #9
slow330
My Ride: 330ci
I see your point! I guess it does make sence, since the 330 is anle to breath more air, and doesnt choke like the 325, thanks !!
I also email Samir and am happy he's willing to help out!
Alot cheaper the ess, which did offer a tune but no help at all, if i had an issue! But you cant blame them, after all its not a kit of their own!
Old 01-27-2013, 10:15 PM   #10
slow330
My Ride: 330ci
So i need a 130mm pulley! Lol
To be specific
Old 01-27-2013, 11:25 PM   #11
TrippinBimmer
My Ride: Just Fast!
To be specific
Why not 125mm hehe
Alpine White M3
MaximumPSI Stage4
Old 01-28-2013, 10:22 AM   #12
slow330
My Ride: 330ci
Lol, well samir offered me a tune for 12psi! But i need cams, and run 93oct
So ill seatle for 9pounds
Old 01-28-2013, 04:39 PM   #13
TrippinBimmer
My Ride: Just Fast!
Do it!
Alpine White M3
MaximumPSI Stage4
Old 01-28-2013, 11:02 PM   #14
xaviman
He told me that my current tune should adapt to the extra boost
Instagram: xaviman
Old 01-29-2013, 07:43 PM   #15
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
I think my pulley is 110mm and it pushes about 10.5. How hard is it to get a copy of it made?
drumbum624 is offline   Reply With Quote
Old 01-29-2013, 07:51 PM   #16
TrippinBimmer
My Ride: Just Fast!
if the parameters doesn't change much but to get max power is to retune.
Alpine White M3
MaximumPSI Stage4
Old 01-29-2013, 10:21 PM   #17
xaviman
It shouldn't be too expensive, a good machine shop will easily do it. Make a couple, I will buy you one
Tripp, how much boost will you run? you will stay with the auto tranny right? Im planing to do it too, but I want to reinforce it to hold the extra power.
Instagram: xaviman
Old 01-29-2013, 11:42 PM   #18
TrippinBimmer
My Ride: Just Fast!
about 15-17psi soon Only, time will tell but yes auto FTW atm...
Alpine White M3
MaximumPSI Stage4
Old 02-06-2013, 07:08 PM   #19
slow330
My Ride: 330ci
So a friend of mines works at the BMW dealer, here in las vegas!
He's an autotech there!
He says if i put 30lb injectors on my car and i can run about 7psi without any tuning! He stated the ms43 is really intelligent and at closed loop the dmw will lean out the injector to run correct afr, but when on open loop the oxygen sensor does not send any signal back to the ecu, therefore the dmw only reads from the MAF sensor and flows at aproxiamatly 90% duty cycle!
Therefore 7psi would have enough fuel to run!
Am comfused! He explain so many things and lost me big time! Also said if i wanted i could use a 10k potentiometer to fool yhe ecu to squirt less fuel if mixture wasnt achieved right! Is he a moron? Or does he know his stuff! WTF??
Old 02-06-2013, 10:04 PM   #20
TrippinBimmer
My Ride: Just Fast!
It's a Ghetto way of Tuning your car...
Alpine White M3
MaximumPSI Stage4
