Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 50 votes, 5.00 average. Display Modes
Old 01-28-2013, 11:06 AM   #41
mintimperial
My Ride: 2003 530i Sport
Yep, /mnt/sdcard is showing empty and non read/write.... I can write fine to mnt/ext_sd/
Is this a hardware or software issue?
Ill try the same thing on the other units i have.
mintimperial is offline   Reply With Quote
Old 01-29-2013, 08:39 AM   #42
mintimperial
Yup, it was just that one unit....the internal sdcard will not mount.
other units are fine and what a surprise, tomtom works great.
any way i can reformat /mnt/sdcard/ without it being mounted. Even a system default reset wont wipe it as it compins about "unknown state" of the internal sd.
Old 01-29-2013, 08:41 AM   #43
PainBreak
My Ride: 2004 325i
Sorry, I didn't get a chance to grab any screenshots of my filesystem yesterday, but I'll do that on my lunch break and get them to you. I do think it can be fixed, I think it's just a screwed partition that needs to be formatted manually.
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
Old 01-29-2013, 09:11 AM   #44
mintimperial
Agreed, dont worry about the screenshot, i have 4 of these still here and just booted another one to see. /mnt/sdcard shows up and reads fine on the second one ive tried...it seems to be corrupted on the first unit.
Old 01-31-2013, 05:06 PM   #45
HighxTech
My Ride: 2002 330i
How do you wire the backup camera so it switches automatically? Mine is wired to reverse lights and plugged into aux in
HighxTech is offline   Reply With Quote
Old 01-31-2013, 05:27 PM   #46
PainBreak
My Ride: 2004 325i
Watch this:
http://www.youtube.com/watch?feature...gbz8v4#t=2m40s
Old 01-31-2013, 05:34 PM   #47
HighxTech
My Ride: 2002 330i
Hm.. i spliced the two pinks together and still get nothing... Does the rca go into the brown connector or the aux in?
Old 02-01-2013, 12:44 PM   #48
jchuillier
My Ride: 330CD
Hello all,
One remaining annoying issue is that Igo does not save the settings, I had read some time ago that the sdcard would not allow write but only read, with the root can we solve this ?
Also what can we do so that ALL apps are allowed to be installed and that we don't have the "your device is not compatible" message, one good exampole is dropbox which cannot be installed.
jchuillier is offline   Reply With Quote
Old 02-02-2013, 01:56 AM   #49
PainBreak
My Ride: 2004 325i
Originally Posted by jchuillier View Post
Hello all,
Issue #1, I would recommend a reinstall of iGo. Mine has always saved the settings just fine. Just that, after saving the settings for the first time, if your DPI isn't set to 145, it refuses to run. There has to be an issue with your installation, I think.
Issue #2, that's something that needs ironed out. It's a simple change in the build.prop file, so that your device looks like something more popular to the Google Play store. To get around it, I just find the actual .apk files (I pull them off of my phone), and install them. After that, they update just fine on the radio.
You could try Market Enabler: http://code.google.com/p/market-enabler/
I haven't tried that yet.
Old 02-02-2013, 03:22 AM   #50
asdetail
My Ride: 2002 325ci coupe
dont splice the two pink wires,just use the one coming out of the radio side of the harness and use the brown rca input, they call it "back sight in" in chinglish,this is working for me and should work for you if everything else is wired correctly
asdetail is offline   Reply With Quote
Old 02-02-2013, 04:09 AM   #51
HighxTech
My Ride: 2002 330i
Where does the pink wire go to?
Old 02-02-2013, 05:31 AM   #52
jchuillier
My Ride: 330CD
I'll try the reinstall of Igo but it came installed on enco's card....I've switched to 120DPI because in 145 the apps in the top row of the screen were halfway off the screen, I have to change the launcher anyway
Thanks for the tip on the apk's I have a workaround for that
Dropbox cannot be installed on the phone BUT in Es explorer you can configure a dropbox network mount, so i'll find the apk's on the phone, send them to dropbox and then get them on the enco with Es explorer and install them from there...
I have a little problem with superuser which is working but not all the time, I'll try to reinstall or perhaps try SUmanager....
Old 02-02-2013, 07:50 PM   #53
asdetail
canbus
Old 02-02-2013, 07:51 PM   #54
HighxTech
My Ride: 2002 330i
canbus
What?
Old 02-02-2013, 08:42 PM   #55
asdetail
check out this:Click image for larger version
Name:	canbus (711x1280) (2).jpg
ID:	489045 note the two wires marked "3",i only used the pink wire that comes from the h/u,not the one that goes to the canbus adaptor harness
Old 02-02-2013, 08:47 PM   #56
HighxTech
My Ride: 2002 330i
check out this:Attachment 489045 note the two wires marked "3",i only used the pink wire that comes from the h/u,not the one that goes to the canbus adaptor harness
So where on the can bus does that wire go to? And I assume the yellow rca goes to the brown connector
Old 02-02-2013, 09:02 PM   #57
Kripas
My Ride: 04 325ci convertible
I would follow what his talking about before asking again.
Kripas is offline   Reply With Quote
Old 02-02-2013, 09:04 PM   #58
HighxTech
My Ride: 2002 330i
Sorry not the can bus. Basically you use the hu pink white but what does it connect to specifically? Sorry for asking so much this stuff cokes naturally to me I'm surprised I haven't got this yet
Old 02-03-2013, 02:32 PM   #59
HighxTech
My Ride: 2002 330i
OK sorry for all the posts, I figured it out.
The yellow rca goes to the brown input. I wired all the wires (including the license plate light cause I was dumb) to the reverse lights. So the led and the camera only come on when Im in reverse
I spliced the two pinks together (which didn't do anything) so I added a wire that goes from the pink (after they're spliced together) to a blue with yellow stripe I located behind the fuse box in the glove compartment. All is good now. Thanks for the support and patience
Old 02-03-2013, 03:47 PM   #60
Kripas
Glad your able to resolved your camera issue.
