Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 50 votes, 5.00 average. Display Modes
Old 02-04-2013, 05:25 AM   #61
cssvb94
My Ride: 320D E46
Guys,
Is your Android unit acts as USB host?
Can you plug USB flash drive and is it detected under Android?
Thank you.
cssvb94 is offline   Reply With Quote
Old 02-04-2013, 06:14 AM   #62
jchuillier
My Ride: 330CD
There is only 1 port that android sees, it's the one in the back where you have to connect the wifi dongle, so the idea is to buy a 12v to 5v converter, and powered USB hub and to install everything behind with some USB extensions cable going to an accesible place. But when you do this (or you remove the wifi) your usb flash drive is seen and it's contents can be used (for music, movies, whatever)
The other back USB prot and the front ones are only here for the radio side of things so they.
jchuillier is offline   Reply With Quote
Old 02-04-2013, 06:18 AM   #63
Marty19
My Ride: 2004 330 ci Vert
Hi all,
Just installed one of these units and trying to get to grips with it. Due to my inquisitive nature I have managed to root it and then apply various changes to the build.prop to screw it up but then managed to get it up and running again by trial and error .... does anyone have the original build.prop so I can get back to where I started from?
Also, I am using a Samba Mobile dongle (for free 3g data) but have to use the PPP Widget to manually connect it everytime I boot up ... any idea's how I can automate this?
Also wanting to install Torque via bluetooth but starting to appreciate this may not be possible ... any progress on this?
Cheers
Marty19 is offline   Reply With Quote
Old 02-04-2013, 06:26 AM   #64
CTRob
My Ride: Alpine white e39
Does the USB hub really need to be powered?
I use a Belkin 4 port USB hub currently with a Dynavin d99+ and that works perfectly.
CTRob is offline   Reply With Quote
Old 02-04-2013, 06:44 AM   #65
cssvb94
My Ride: 320D E46
Thank you for the reply
Old 02-04-2013, 06:48 AM   #66
jchuillier
My Ride: 330CD
Well, since the 12v to 5v power supply is at $5 yes I would power it, so that it could even recharge the phone
Old 02-04-2013, 04:42 PM   #67
kaciker
My Ride: E90 320d
Hi guys
I have the model Enco B-090, for my E90
I understand that everything you write here is also valid for this model.
Is that so? especially the root issue..
Tcc8925 1.2g cpu
http://szenco.en.alibaba.com/product..._Function.html
kaciker is offline   Reply With Quote
Old 02-05-2013, 12:20 AM   #68
Kripas
My Ride: 04 325ci convertible
Originally Posted by HighxTech View Post
OK sorry for all the posts, I figured it out.
The yellow rca goes to the brown input. I wired all the wires (including the license plate light cause I was dumb) to the reverse lights. So the led and the camera only come on when Im in reverse
I spliced the two pinks together (which didn't do anything) so I added a wire that goes from the pink (after they're spliced together) to a blue with yellow stripe I located behind the fuse box in the glove compartment. All is good now. Thanks for the support and patience
Like this?
Kripas is offline   Reply With Quote
Old 02-05-2013, 02:39 AM   #69
kaciker
My Ride: E90 320d
Originally Posted by mintimperial View Post
Yup, it was just that one unit....the internal sdcard will not mount.
other units are fine and what a surprise, tomtom works great.
any way i can reformat /mnt/sdcard/ without it being mounted. Even a system default reset wont wipe it as it compins about "unknown state" of the internal sd.
Hi
I have exactly the same problem. My SDcard is empty, and no system come to it.
Apparently is not mounted. Did you manage to solve this topic?
Old 02-06-2013, 10:25 AM   #70
PainBreak
My Ride: 2004 325i
Originally Posted by Marty19 View Post
Hi all,
Cheers
You can extract the original build.prop from this file. You'll probably want to change your display's density though.
Not sure on the 3g dongle thing.
I don't know of a bluetooth adapter that works at the moment, as I haven't been able to test any. However, there are USB and Wifi ELM327 devices that should work fine with Torque.
It doesn't need to be powered, unless you're using a device that requires more power than the USB port pushes, such as an external hard drive. USB sticks / dongles / etc should be plenty happy with the current bus power.
Originally Posted by kaciker View Post
Hi guys
Tcc8925 1.2g cpu
Root should be the same for this model.
Hi
Mintimperial can help you with this one. There's a modification that can be made to the vold.fstab file that should resolve the issue with it reporting the internal SD as damaged.
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
Old 02-06-2013, 11:08 AM   #71
kaciker
My Ride: E90 320d
Confirmed, i tried and it works, the root Enco B-046 = Enco B-090
Thanks I have sent a pm to Mintimperial myabe I have good luck
Another topic... you know how delete this, when the car is moving ??
Old 02-07-2013, 07:01 AM   #72
jchuillier
My Ride: 330CD
Yep, in the main radio settings, make sure the brake setting is to OFF
Old 02-07-2013, 11:04 AM   #73
kaciker
My Ride: E90 320d
Thanks ¡¡
Already I found it. The translation to the Spanish is so bad, that did not have anything to see with this...
Another question.
When I power on the radio, all the radio memories are lost. Also the parameters of ecualización (bass, treble, et)
What is the problem ??
Old 02-07-2013, 11:53 AM   #74
///MPR77
My Ride: 02 ///M3 Tri-Ped
Great write-up.
I just read the entire thread, and don't even have this unit.
Sub'd for the future.
Old 02-07-2013, 12:57 PM   #75
jchuillier
My Ride: 330CD
Thanks ¡¡
Another question.
You can imagine what the french translation is ha ha ha...
About the settings I had the same problem but after a while they stayed, maybe there is a rechargeable battery in it and it takes a while before being ready to save the settings....
The guys that have opened their units here will help you on this
Old 02-08-2013, 02:57 AM   #76
Marty19
Smile
Just to let you know that Torque works fine via USB
Old 02-08-2013, 03:08 AM   #77
jchuillier
My Ride: 330CD
Which dongle where to buy it ? Thanks
Old 02-08-2013, 03:16 AM   #78
Marty19
Just tried a cheap one from eBay http://www.ebay.co.uk/itm/150979991593 and all is good
You will need Torque Pro in order to use USB input.
Old 02-08-2013, 04:29 AM   #79
kaciker
My Ride: E90 320d
Help ¡¡ maybe my battery not works ??
Old 02-08-2013, 04:36 AM   #80
jchuillier
My Ride: 330CD
Thanks for the link, just bought one....
