Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 50 votes, 5.00 average. Display Modes
Old 02-18-2013, 04:13 AM   #101
Marty19
My Ride: 2004 330 ci Vert
I have just installed a powered USB hub in order to connect all of my USB devices at once and this is working fine.
I am sure I read somewhere that it was possible to keep the Android side of the unit 'alive' via USB power when the car ignition is off. This would remove the long boot up time I currently have but is is really possible?
Failing that, does anyone have any tips for improving the Android boot time?
Marty19 is offline   Reply With Quote
Old 02-19-2013, 11:25 AM   #102
jchuillier
My Ride: 330CD
For the Android boot time I have the solution....
I go out of the house 5 minutes before leaving, turn the car on with the seat heater on, my old ass is warm and Android is booted up
Seriously it's also not a bad idea to start the engine 5 mins before leaving to get water and oil at the proper temp, then all you need to od is being careful for the first 5 minutes to warm the gearbox and THEN you can be the road warrior
jchuillier is offline   Reply With Quote
Old 02-19-2013, 02:52 PM   #103
cssvb94
My Ride: 320D E46
Is it my imagination or after rooting and applying the framework the GPS fix time is less and more accurate?
cssvb94 is offline   Reply With Quote
Old 02-22-2013, 06:27 AM   #104
chouch
My Ride: X5
After toying this things and going through every detail, I do not recommend buying this unit for anyone; It is simply not worth the money:
- China is China: First item shipped to me was not working, missing lots of cables ... had to return for another unit which cost me an additional $140 shipping and custom charges
- Bluetooth and Steering Control: bluetooth is only on wince part and not working on Android side. If you pair your mobile (in my case iphone 4) with the device, the steering control works 1 in 10 times ... unbearable!
- Radio and Sound: Sound is very loud in my case (x5 2001) and installing a LOC (based on the reviews) does not solve the problem. The radio software is a disaster, the steering controls does not change channel, instead it changes the channel frequency
- Random Selection on boot: it has its own mind, on almost every boot, the system decides where to go and it is something very annoying
- Fan: not matter what you do, within a 30min of operation the fan will turn on and it is louder than your music (Yes the unit installed properly and nothing is blocking the fan)
- iPOD: the UI sucks, there is no album cover or anything
You get what you paid for? Actually that is not true, I got less then what I paid for, this unit is worth absolutely nothing ... there is no support to back it as well.
If you think you can live with the downsides aboves, then probably this unit is for you.
chouch is offline   Reply With Quote
Old 02-22-2013, 06:47 AM   #105
Marty19
As with most things, there are those who have a good experience and those that have a bad one. My experience was a little better than Chouch.
- unit installed easily and looks good
- sound is better than factory unit
- supplied wifi dongle did not work but replacement purchased from ebay
- used usb hub to also connect 3g dongle. One supplied by Samba Mobile did not work but replacement purchased from ebay
- finally got Torque working though usb but have since decided I probably wont use it very often (but at least it works!)
Overall I am happy with the unit. I looks good, sounds fine, plays music, video and radio with no problems. Android a bit slow to boot but can live with that. Connections to wifi and 3g all setup and working and Candy Crush Saga installed for those Traffic Jam moments
Old 02-22-2013, 10:57 AM   #106
TaintedSoul
My Ride: E46 M3
Hi chaps,
First like to say this is probably the most productive thread to date on the Android units!! And hacking of the ROM is great to see.
Although I have the ENCO B06 2.3 Android and it's far from nice.
Problems:
1. No sound in Android, tried various sound settings and nothing works. I know Bluetooth from phone and use phone. No what I had in mind.
2. Click on GPS and it crashes to Android desktop.
Now a question to all the people? WinCE side and Android. Everyone seems to indicated that both WinCE and Android are running on these units together?
Unless this board has advanced virtualization running that's impossible. It's either WinCE running or Android. Both will have an overlay over desktop OS. Someone please correct me?
TaintedSoul is offline   Reply With Quote
Old 02-23-2013, 10:07 AM   #107
jchuillier
My Ride: 330CD
Originally Posted by Marty19 View Post
Just to let you know that Torque works fine via USB
Hello Marty,
Got my USB ODB adapter, the blue one from your Ebay link.
It is seen by android because it tells me it want to start torque when i plug it in but I can't get the adapter to talk to torque pro 1.5.70 which is supposed to be the last one...
Can you tell us about your USB settings ? Speed, device and so on ?
Old 02-25-2013, 07:26 AM   #108
Marty19
Originally Posted by jchuillier View Post
Hello Marty,
Only settings I have set are:
Connection Type: USB
Faster Communication: ticked
USB Device: 1027
Baud Rate: automatic
Old 02-25-2013, 03:00 PM   #109
daki_bmw
My Ride: 330Ci
...Seriously it's also not a bad idea to start the engine 5 mins before leaving to get water and oil at the proper temp...
OT (I try to stay away from Android threads) but I had to mention it - no, actually it's not a good idea. Read your owner's manual. Also, there are tens of threads about this. Diesels should be very similar.
daki_bmw is offline   Reply With Quote
Old 02-26-2013, 03:11 PM   #110
Crnagora94
My Ride: BMW
hello friends,
I have a question. I have the old version 2.3 and have had many problems with the software. I can use the update from post 1?
thank you
Crnagora94 is offline   Reply With Quote
Old 02-26-2013, 03:53 PM   #111
kaciker
My Ride: E90 320d
The provider has given us solution to enter to recovery mode for the unit Enco B090.
I have read everything, and I do not see anyone saying anything about this.
The system is easy,
Put you rom in the root of the sd (update)
Then open the lower cover unit.
With a thin cable that has a piece looking for ground, and with the other end of the pin number 13 (the photo).
Now, turn on the unit and go to the Navi, Then the robot start in recovery mode and load the rom.
It's easy right?
I've tried it two times and it works (bmw e90 B090) even if the unit is practically the same as for e46
Tanks to jmorales bmwfaq.com spain
kaciker is offline   Reply With Quote
Old 02-28-2013, 03:09 PM   #112
kaciker
My Ride: E90 320d
Torque by usb, whit hidden wires
Old 03-02-2013, 12:57 PM   #113
monty13
My Ride: 1999 e46 323i
The system is easy,
It's easy right?
Does anybody have an update file for the 'old' android 2.3 version? My android side is still stuck in a bootloop, but I'm guessing I can use this method to get out of it. Just thinking I will need a clean ROM to update it with...
monty13 is offline   Reply With Quote
Old 03-02-2013, 03:37 PM   #114
asdetail
My Ride: 2002 325ci coupe
Originally Posted by Kripas View Post
FYI this is her. Got from her signature mail.
def charles with wig
asdetail is offline   Reply With Quote
Old 03-05-2013, 10:38 PM   #115
tnhl1989
My Ride: 02 330xi(RIP),03 ZHP
Just got my unit. I will update you all how everything goes.
tnhl1989 is offline   Reply With Quote
Old 03-06-2013, 01:34 PM   #116
tnhl1989
Seems like the android sound works a lot better now.
On a side note the mediafire file is gone. Does anyone have this file?
So overall the android screen stop functioning. I tried the force recover up top. However now nothing shows up when I click Navi. What to do now?
Old 03-07-2013, 05:33 PM   #117
tnhl1989
I tried this but I don't believe it actually works.
Old 03-07-2013, 10:33 PM   #118
monty13
Old 03-08-2013, 12:28 AM   #119
tnhl1989
Now the android side doesn't even work going to have a chat with charles soon.
Old 03-08-2013, 06:17 PM   #120
PainBreak
My Ride: 2004 325i
It sounds to me as if you jumped in with both feet, without knowing how to swim. I don't mean to sound like a jerk, but from the PMs I received from you, and your posts in this thread, I still haven't been able to figure out why you would take your radio apart, and try to jump the pins. Did you think that was necessary in order to root the device? Because it's not.
In other, unrelated news, I believe I have a fix for what I like to call the "Enco Shuffle" where the CANBUS interface starts randomly selecting a screen at startup. This would be for pretty much every Enco radio with this issue, both WinCE and Android. More on this to come...
Is your car a Stu Stu Stammering Stan at 2800 RPMS? FLASH THE DME! http://forum.e46fanatics.com/showthread.php?t=966614
Enco B046 Android 4.04 Root/FAQ/Help: http://forum.e46fanatics.com/showthread.php?t=967737
PainBreak is offline   Reply With Quote
