///M3 Forum
Old 01-26-2013, 03:54 AM   #1
nawewawe
My Ride: 03 M3 Hardtop/Vert
Need your opinion
I have a M3 vert and looking to add some new rims to my car. Im interested in purchasing a set of VMR v718 with a drop. My wheel specs i chose are R-19x9.5 F-19x8.5, since thats the biggest size these wheels are made, would have loved 19x10 in the back and 19x9.5 fronts any how, im really confused about the offsets. I tried to research it but, im still confused. This is where u guys come in. Basically i want my tires to sit flush at the fender with my fenders rolled of course with a clean drop. what would be the max offset that the wheel stick out without any rub?
Photobucket
nawewawe is offline   Reply With Quote
Old 01-26-2013, 02:57 PM   #2
nofar
My Ride: 2006 M3 ZCP 6 SPEED
You need to provide the offsets. The offsets will determine how far inboard/outboard the face of the wheel will sit relative to the fender. Honestly, there's no one perfect combination. You should search intensively and you'll find the information you require.
If you already have the wheels on the car and are looking for spacers, then you need to measure the gap between the wheel and the fender and that will tell you what spacers to get (assuming you live some room left over too).
2006 M3 ZCP. Interlagos Blue on Dove Grey. 6 speed manual.
Eibach Pro-Kit / Koni externally adjustable F&R shocks / DDM Aluminum Pedals / BMW Performance Short Shift Kit / Clutch Delay Valve (CDV) removed / Painted reflectors / Stealth bulbs / Turner 15mm/10mm front/rear spacers.
nofar is offline   Reply With Quote
Old 01-27-2013, 10:50 PM   #3
illestminimike
My Ride: Project Drama
One of our sponsors will come in and help you. Call Modbargains. They can help you.
Old 01-28-2013, 07:00 PM   #4
Ntrb8s4
My Ride: X5 / B8 S4
Talk to Elliot at mod bargains. He's the man! I'm ordering my wheels from him tomm!
Ntrb8s4 is offline   Reply With Quote
Old 01-28-2013, 07:28 PM   #5
taylor192
My Ride: 2003.5 M3
That's a difficult question to answer cause:
- Rolling fenders isn't an exact science, you could roll them mildly, or you could even push them out.
- You could as some people do here, run wide wheels with stretched tires. It gives you that "flush" look, yet only if you ignore the tires are stretched to hell.
- What's a "clean drop"?
Contact a vendor, you're probably going to have to pay extra for custom offsets, which then you may rethink your choice.
Old 01-29-2013, 07:40 PM   #6
nawewawe
sounds good. i dont live to far from mob bargains also i can save money on shipment. so ill just roll up there and check them out. One more question how much does stock premium 19 inch rims weigh at comparing to some vmr v718
Photobucket
Old 01-29-2013, 07:50 PM   #7
nawewawe
I Basically want my car to look and sit like this car but with v718 instead of vb3. PS I have a hardtop aswell. here are his specs:
VMR VB3
19x9.5 +22 235.35.19 60%
19x10 +25 245.35.19 brand new
Photobucket
vmr v718 m3 vert
