Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
View Poll Results: Safe crank HP
400 HP 2 15.38%
425 HP 6 46.15%
450 HP 2 15.38%
500 HP 3 23.08%
Voters: 13. You may not vote on this poll
Old 01-24-2013, 03:05 PM   #1
bimmerguy055
My Ride: turbo 3'er
Send a message via AIM to bimmerguy055
Max and/or safe HP for m54
I'm currently at what I think is safe power for the m54b25 at ~400 crank HP, and it seams erratic on the data I'm finding on what these motors can take, and what the safe area is for DD.
Without Failure There is No Success
352whp@ 10PSI stock 2.5L internals!
@ 20PSI with unknown power
bimmerguy055 is offline   Reply With Quote
Old 01-24-2013, 03:10 PM   #2
serdar255
My Ride: '01 325ci / '90 325i
Sorry, I have no info, but can I have some details on your set up? If you want you can PM me, I want to do a custom turbo next year
thanks
Bump for you anyway
Want a handmade shift knob or custom vinyl stickers? PM me
I'm sixteen and like cars with three pedals.
My ever small company... www.facebook.com/StgFabricationAndMolds
serdar255 is offline   Reply With Quote
Old 01-24-2013, 03:28 PM   #3
Think0rz
My Ride: 05 AW M3
I dont believe anyone can give you X amount of HP as a FACTUAL answer and back their claims with documented proof. The true answer honestly is "its all the in the tune" & If you have a healthy platform to build upon, having a realistic HP number in mind a tuner will be able to shine real light on your question. GL with your quest
Think0rz is offline   Reply With Quote
Old 01-24-2013, 03:43 PM   #4
bimmerguy055
My Ride: turbo 3'er
thanks
Bump for you anyway
check out my mods in my garage
Its not about a pin-pointed "X amount" but rather gathering everyones data then making a average. A good tune can ONLY go so far, it doesn't make you bullet proof to a weak part I.E connecting rods. My tune is 95% spot on, just having ICV issues.
BTW all I have done internally was a slightly thicker HG and raceware head-studs, everything else STOCK!
Old 01-24-2013, 03:47 PM   #5
zx5rider
My Ride: TT Turbo 2003 330i
Send a message via AIM to zx5rider
Well I'm shooting for 500ish with the same as you plus CP pistons.
Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around
2011 BMW S1000rr
zx5rider is online now   Reply With Quote
Old 01-24-2013, 05:38 PM   #6
daemonicus
My Ride: batmobile
what tune are you running?
daemonicus is offline   Reply With Quote
Old 01-24-2013, 06:09 PM   #7
bimmerguy055
My Ride: turbo 3'er
custom tune, (based on the 330 calibration) out of the Pro EFI EMS
Old 01-24-2013, 06:11 PM   #8
bimmerguy055
My Ride: turbo 3'er
Just CP pistons? where you getting them? VAC?
Old 01-24-2013, 07:47 PM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
You probably hold the record for a 2.5L M54....But the 3.0L record currently sits at 570rwhp.
Keeping the head gasket happy seems to be a problem for 280rwhp N/A race engines up to the 570rwhp turbo setup.
Old 01-24-2013, 07:58 PM   #10
bimmerguy055
My Ride: turbo 3'er
Theres got to be someone out their with a higher 2.5L number. Whats the details on the 570whp 3L? Once I have a spare motor on the side i'll push mine for more
Old 01-24-2013, 08:50 PM   #11
Edgar3498
My Ride: 330CI
Your gping to blow up haha
Hey send me a txt I lost all my contacts
Are you going to the meeg
Sent from my SGH-T999 using Bimmer App
Edgar3498 is offline   Reply With Quote
Old 01-25-2013, 12:33 PM   #12
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
I am AA Stage 2 335.1 at 6000 RPMs I am going to do Meth injection and eventually FI Cams.
So if you calculate normal drive train loss I am around 385 at the crank. So I hope after Meth and cams I can do a pull to 6800-7000 for a more accurate number.
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 01-25-2013, 01:14 PM   #13
bimmerguy055
My Ride: turbo 3'er
not bad. Whats your timing table like? must be very conservative? I'm only running 13-14 up top, so I have a gap to play with to be safe (plus if I get crappy gas, I wont have to worry)
I wouldn't worry about meth, if you have a decent tune, something in your engine, or clutch/auto trans will give before you'd need meth. (assuming your running a good sized FMIC)
Also our intake mani's are horrible for meth (meth puddles behind the throttle body, and can give AFR errors), unless you install a nozzle for each runner.
Old 01-25-2013, 05:34 PM   #14
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
M54B30 with CP low compression pistons and eagle rods. Head is mildly ported, with some up-rated cams. 6262 turbo tuned with Vipec V88 ECU. I'm pretty sure they are running E85...as they made 500rwhp with a stock bottom end on a pretty similar setup.
Again, I think you have the record for an M54. Sure there are a few M50s making decent power with a 2.5...but very few people take on the M54 because of the VANOS. (And the DME is virtually un-tunable for the average person)
Do you have a runfile from your dyno? I would be very interested in a .drf file from a dynojet....kind of building a library of M54 stuff.
Old 01-25-2013, 07:00 PM   #15
bimmerguy055
My Ride: turbo 3'er
Is there a build thread of this? I think I know the guy your talking about. Did he run a china GT35R for a while? In Sweden?
Well you probably know there is software out that can tune the stock DME. But I went the Pro EFI route. All I have is a video clip that shows the screen of the dyno run below.
Old 01-26-2013, 03:22 PM   #16
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Different guy...no current build thread on what's in the car. If you search for Jimmy Oberg here you'll find what he was up to a couple of years ago.
