Old 01-26-2013, 05:15 PM   #1
sfcjetjr
My Ride: 2002 BMW 325i
Amsoil usage?
Any benefit either way of using lower weight vs up to 20/50? I use 20/50 in the hog. Car is at 137,000. 2002 325i.
sfcjetjr is offline   Reply With Quote
Old 11-04-2013, 09:08 PM   #2
rdhamill
My Ride: 2005 330i
lower weight oil will flow easier, pump easier and cause less load on the engine. The heavier oil might lead to excessive cylinder bore wear.
it's best to stick to the factory's viscosity.
rdhamill is offline   Reply With Quote
