indicator bulb replacement - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-27-2013, 02:38 PM   #1
oriole
My Ride: 2002 330 convertible
how do i get at the front parking/indicator light bulbs to replace?. the owner's manual doesn't help.
oriole is offline   Reply With Quote
Old 01-27-2013, 03:21 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
- Pop the hood
- Look above the corner light, you will see a hole that will either show a philips head screw (+) or a flat piece.
- If it's the philips head take a screwdriver and loosen it then the corner will pop out
- If it's flat then push down on it and it will pop the corner out
Old 01-28-2013, 01:15 AM   #3
christiandflores
My Ride: BMW M3 E46
maker sure you have the correct bulb, should be 1156 i believe
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | 6MT | SMG | 40% Tint | Full LED Interior/Exterior | Michelin PSS 275/30/19 square set up
https://www.facebook.com/SanDiegoBmwMeet
christiandflores is offline   Reply With Quote
Old 01-28-2013, 02:09 AM   #4
cityjohn
My Ride: 2001 M3
The correct bulb would be clear #7506 if you have orange lenses, and amber #7507 if you have clear lenses. Car made before 2003 should use the push-in style of lamp assembly rather than the screw-in type.
cityjohn is offline   Reply With Quote
Old 01-29-2013, 08:19 AM   #5
wvBimmer3Series
My Ride: '92 318ic, '01 325xi
I found a video on YouTube showing me how to do this.
Good luck.
wvBimmer3Series is offline   Reply With Quote
Old 02-27-2013, 10:25 AM   #6
TotheMountains!
My Ride: 2001 330xi
The owner's manual for my 2001 330xi is reasonably helpful, and the Bentley offers just a little more. That You Tube video is here:
What none of them warn about is that even gentle pressure on the 12-year-old plastic spring clip release is likely to break it if you're not extremely careful. Broke one Saturday, had its replacement from Bavarian Auto on Tuesday. Then the spring clip proved too strong when new, and I was very reluctant to force the light unit back into place. I tested/inspected the driver's side several times to understand fit & function, managing to break the plastic spring clip on that one in the discovery process; it's now held in by tape.
The secret to the passenger side unit that could not be gently forced back in far enough for the clip to engage and lock it in: filing back the notch on the spring clip, maybe 1mm. Not all plastic moldings will fit all cars as they come from the factory. I had everything right, but the clip was just a few c-hairs from engaging. After a little time with a file I managed to get it clipped in; she is some wicked tight now.
When I find a good parts car, I'm going to strip all the lights out of it.
TotheMountains! is offline   Reply With Quote
