Old 01-28-2013, 02:34 PM   #1
Jerry299
My Ride: 2003 325i
2003 325i w/ halogen headlights
Hey everyone this is my first post so please bear with me. Yesterday i bought a 2003 325i and i want to convert the headlamps from halogen to HID. Can i just buy the OEM stock HID headlight assemblies that were offered for that year? I was looking at pictures and they look like the connectors match up and all but without having them in front of me i cant tell for sure. Any advise will help, thanks!
Jerry299 is offline   Reply With Quote
Old 01-28-2013, 04:02 PM   #2
christiandflores
My Ride: BMW M3 E46
Yeah, you should be able to, coding might be needed.
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | 6MT | SMG | 40% Tint | Full LED Interior/Exterior | Michelin PSS 275/30/19 square set up
https://www.facebook.com/SanDiegoBmwMeet
christiandflores is offline   Reply With Quote
Old 01-28-2013, 04:03 PM   #3
christiandflores
My Ride: BMW M3 E46
I'd double check on connections though
- Christian
Old 01-28-2013, 10:48 PM   #4
Jerry299
My Ride: 2003 325i
I'll keep doing some research but if coding is all that's needed than it might be worth it..I'm also looking into the OEM retrofit kit. Thanks for the response!
Old 01-28-2013, 11:04 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Click on "projector retrofit" in my sig below, do that.
Old 01-28-2013, 11:13 PM   #6
christiandflores
My Ride: BMW M3 E46
think about doing projector foglights too, if you dont get much fog in santa barbara. i know we dont down here in san diego
- Christian
Old 01-28-2013, 11:45 PM   #7
Jerry299
My Ride: 2003 325i
Sweet I'll look into that too..any brand you'd recommend for that?
Old 01-29-2013, 01:17 AM   #8
christiandflores
My Ride: BMW M3 E46
ebay projectors like these. they come in chrome and black. but if you do what i did, color doesnt matter, its the projector part you want. you have a 325i, so unfortunatley you might not have the correct set up.
i reused the OEM foglight housing, disassembled the cover from the projector, then inserted the projector into the OEM housing. only 2 holes required. i used morimoto h3c HID 4300k bulbs in mine, perfect match to the OEM xenon color. they look pretty much OEM when off
btw, if you do convert your headlights, try to get actual 4300k bulbs like OEM color not the ***** blueish white ones, theretrofitsource.com has some good stuff.
http://www.ebay.com/itm/BMW-2001-200...08f0e4&vxp=mtr
http://forum.e46fanatics.com/showthr...or+fogs&page=2
Off
_MG_3325
On
_MG_3307
- Christian
Old 01-29-2013, 01:57 AM   #9
Jerry299
My Ride: 2003 325i
Good info! I think I'm gunna get the OEM retrofit kit so I'm sure they come with the correct bulbs but ill check that before buying them. Thanks a bunch.
Old 01-30-2013, 01:38 AM   #10
Jerry299
My Ride: 2003 325i
Just noticed this post. Did you do both high and low beams??
Old 01-30-2013, 04:52 AM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yes I did.
