Old 01-28-2013, 07:10 PM   #1
Jussblazn
My Ride: 2004 330ci
correct xenon bulb?
So it froze a couple weeks ago and my passenger side headlight went out on my 2004 330ci. Took it to the dealership to have them look at it. They came back and said the bulb went out, and that I need a new one. I asked how much, they said >$240 for just the bulb. That's just crazy.
Anyways after a bit of research. It seems that I need a new d2s bulb correct? I looked on amazon and there's a bunch of them. Which one should I get? I want something that's white. 5k? 6k? If someone could recommend a set, that would be great.
I saw someone recommend these while browsing on another forum.
https://www.theretrofitsource.com/pr...oducts_id=1250
Are they any good?
Thanks for the help
Jussblazn is offline   Reply With Quote
Old 01-28-2013, 08:00 PM   #2
DOT.
My Ride: '04 ZHP Sedan
Yes, they are great replacement bulbs if your not going with Philips or Osram.
DOT. is offline   Reply With Quote
Old 01-28-2013, 09:02 PM   #3
Jussblazn
My Ride: 2004 330ci
any recommendations for a pair of philips or osram bulbs?
Old 01-28-2013, 11:08 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Read my sticky for the lighting guide. I have a link there explaining the different temps for each bulb.
If you want white color get either Philips Ultinon which are around $100 on ebay for genuine or get THE best bulbs Osram CBI which cost $185 from TRS.
The Morimoto's are good if you're on a budget.
Old 01-29-2013, 03:05 AM   #5
Jussblazn
My Ride: 2004 330ci
Ordered a set of D2S: Morimoto 3Five. Thanks for the helps guys
Old 01-31-2013, 02:11 PM   #6
Jussblazn
My Ride: 2004 330ci
Installed and looking good.
edit: will take some pics tonight
Old 01-31-2013, 05:55 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Any pics?
Old 01-31-2013, 11:23 PM   #8
Jussblazn
My Ride: 2004 330ci
pics as promised
http://i.imgur.com/qLx6eCm.jpg
http://i.imgur.com/EnodqCn.jpg
http://i.imgur.com/OjveG5y.jpg
Old 02-01-2013, 11:22 AM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Looks nice. How is the output?
Old 02-01-2013, 07:20 PM   #10
Jussblazn
My Ride: 2004 330ci
It lights the road up at night, much more visibility than the stock bulbs. Now I want to change my fog lights.
Old 02-04-2013, 06:14 PM   #11
Jussblazn
My Ride: 2004 330ci
Hey guys, after installing the new bulbs and driving around for a few nights. The passenger side headlight started flickering and then went out completely. Curious, I popped open the cover to take a look inside. I noticed that the green wire the connects to the igniter had broken. I tried searching realoem.com to find the part, but no luck. Anyone know what part this is and where I can get a replacement. I need some help identifying the part number for the wires that connect to the igniter in the headlights. I've attached a pic to help.
Thanks for the help.
Old 02-04-2013, 07:41 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
See if you can splice the wires together, solder them and use heatshrink. Then it will be good as new.
Old 02-05-2013, 06:25 PM   #13
Jussblazn
My Ride: 2004 330ci
^Will try that.
Edit: fixed!
Old 10-24-2013, 11:21 PM   #14
Isaac H
My Ride: BMW M
Hey guys, hate to bring up an old thread but I got the same problem except it is my red wire that is broke.
Do I need to take any precautions besides turning off the headlights to begin? Will they splice and reconnect just like home stereo wiring? If anyone could dumb the process down for me, that'd be great!
Isaac H is offline   Reply With Quote
Old 10-25-2013, 09:11 AM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
Disconnect all the plugs from the headlight and try to solder the wires together or splice them. Use heat shrink and electrical tape as a precaution.
Old 10-25-2013, 09:20 AM   #16
Isaac H
My Ride: BMW M
Thanks. Do you know where this plugs into the headlight?
This is the wiring that plugs into the igniter on an 04 coupe.
Old 10-26-2013, 09:34 AM   #17
Solidjake
Zero. Leaks.
Solidjake's Avatar
PM Sillieidiot, he will know better for the facelift coupes.
Old 10-26-2013, 12:31 PM   #18
Isaac H
My Ride: BMW M
Thanks for your help! Headlight is working again. Any idea what the part number is for the dust covers that you need to pop off to access the bulb/igniter?
