E46 Xi Forum
Old 01-28-2013, 08:00 PM   #1
mixedgas401
My Ride: 04 325xi
Brake upgrade for my 325xi
So I bought a set of 17inch wheels and I have a huge void that needs filled in my wheel. I believe 330xi brakes are bigger so question is what is necessary to change my car over to the 330 brakes.
My car is a 2004 325xi. Also I was just planning on doing the front but is there a difference for the rear?
Sent from my AT100 using Bimmer App
mixedgas401 is offline   Reply With Quote
Old 01-28-2013, 08:20 PM   #2
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
Do only front. You cannot retro the rear 330 brakes on a 325 without changing a lot of parts (half shafts etc), or you risk losing your parking brake.
http://forum.e46fanatics.com/showthr...389&highlight= Some more info from my experience.
-Brendan
Old 01-28-2013, 08:30 PM   #3
mixedgas401
My Ride: 04 325xi
My ebrake don't work anyway. So would changing calipers pads and rotors do the rear? It appears the front is a simple CPR swap?
Old 01-28-2013, 08:31 PM   #4
Kubica
My Ride: 2003 325xi
That is 100% incorrect. 330 rear brakes fit a 325xi no problem.
OP- you need rotors, pads, and calipers with brackets. That's it.
Old 01-28-2013, 08:33 PM   #5
simsima325
simsima325's Avatar
Is that due to different rear trailing arms on Xi cars?
Read my thread and you will see why this is NOT a direct swap on non Xi cars.
-Brendan
Old 01-28-2013, 08:33 PM   #6
simsima325
simsima325's Avatar
and if OPs ebrake doesn't work, have you tried tightening the cable!?!?!
-Brendan
Old 01-28-2013, 08:44 PM   #7
mixedgas401
My Ride: 04 325xi
Never mind. It helps if I read it all. I'm going to call off the rear upgrade for now.
Old 01-28-2013, 09:18 PM   #8
mixedgas401
My Ride: 04 325xi
I wouldn't mind doing the whole conversion. I have no problem cutting the shields to make the rotors fit and the ebrake isn't much of a concern since my car is an automatic
Old 01-28-2013, 10:07 PM   #9
Kubica
My Ride: 2003 325xi
Yes. All 330's have xi trailing arms. I explained this in a thread a few weeks ago.
You are in the xi forum. Everything is under control. Thanks for checking in. Bye.
Old 01-29-2013, 06:34 AM   #10
mixedgas401
My Ride: 04 325xi
Wait .......!!!!! I'm confused. Is this a direct swap or not? I understand the front is but what about the rear?
Sent from my HTC One X using Bimmer App
Old 01-29-2013, 11:58 AM   #11
SamDoe1
My Ride: 4cyl of fury
Untrue.
^ This.
Yes, the 325xi has the same trailing arm as the 330xi and the 330i. If you look for rear brake rotors, you will find that there is a rotor for the 325i, 330i/xi (interchangeable rotors), and 325xi. Rear rotors are NOT interchangeable between the 325i and 325xi. The difference between the 325i and 330i rotors are in the hats and overall diameter. The difference between the 325xi and the 330xi is just in the overall diameter, the hats are the same and therefore the ebrake will work just fine.
The 325xi, 330i, and 330xi all use the same rear suspension.
You will need to swap calipers, carriers, pads, and rotors on both front and back. No need to mess with trailing arms or any of that sort of thing.
Good luck.
PS: Might I ask what you're looking to get out of this brake "upgrade" other than some extra unsprung weight?
Old 01-29-2013, 12:06 PM   #12
mixedgas401
My Ride: 04 325xi
I need a front caliper and all around brake job so I want to just do everything new since I financed this car and am stuck with it for three to five years. It is mainly for looks, so it fills in my wheels better. I have 17s and the 325 brakes look tiny in my wheels
Old 01-29-2013, 12:36 PM   #13
simsima325
simsima325's Avatar
No need to be a dick. Congrats on your expansive knowledge of such a fine automobile as the Xi E46.
OP GL with the upgrade, sounds like it might be easy to do the full 330 brake upgrade. I enjoyed my front 330 setup while I owned the car. More consistent braking and it filled out the wheels nicely. Should have been standard from the start on 325.
-Brendan
Old 01-29-2013, 12:39 PM   #14
mixedgas401
My Ride: 04 325xi
Thanks. I'm def excited now that is so easy and I'll be under 200 for all four calipers.
Old 01-29-2013, 12:46 PM   #15
SamDoe1
So you're doing this only for looks then? Please realize that the larger brakes will have more unsprung weight and will therefore negatively impact your handling and performance.
Old 01-29-2013, 08:17 PM   #16
mixedgas401
My Ride: 04 325xi
Yeah I understand that but as time goes on I plan to do more upgrades. Within two years I hope to be knowledgeable enough with the software end of these cars to do some sort of forced induction. So not everything is only for looks. I'm going to weigh the calipers and rotors from the 325 and 330 as well. I will post up the differences.
Old 01-29-2013, 08:23 PM   #17
bmwporschefan
My Ride: 2001 330xi
Please do this now that this thread has got my curiosity.
'01 330xi
bmwporschefan is offline   Reply With Quote
Old 01-29-2013, 08:26 PM   #18
mixedgas401
My Ride: 04 325xi
Well I can't do it right now. I will do it as soon as I have everything together.....which will take a few weeks. Also I will be sure to drain all fluid from the old calipers to make this as accurate as possible
Old 01-29-2013, 08:29 PM   #19
bmwporschefan
My Ride: 2001 330xi
Lol I didn't expect you to do it right now. Just when you get to it.
'01 330xi
Old 01-29-2013, 08:31 PM   #20
mixedgas401
My Ride: 04 325xi
Also I would like to add that I converted an e36 to m3 brakes which I believe are similar part wise and I would guess that it was approximately 5-10 pounds in weight difference. We didn't actually weigh everything but it was for a race car and my boss and I guessed about what was being added. It was only small amounts in the rotors
