Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 01-28-2013, 09:07 PM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Front Comp Pkg calipers
Sold
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-29-2013, 07:14 PM   #2
bigjae1976
bigjae1976's Avatar
Ttt
Old 01-30-2013, 10:21 AM   #3
bigjae1976
bigjae1976's Avatar
$200
Old 02-04-2013, 10:17 PM   #4
bigjae1976
bigjae1976's Avatar
bump
Old 02-06-2013, 04:05 PM   #5
bigjae1976
bigjae1976's Avatar
bump
Old 02-07-2013, 11:30 AM   #6
bigjae1976
bigjae1976's Avatar
$175
Old 02-07-2013, 12:59 PM   #7
adamdifilippo
My Ride: The M
Difference between non-ZHP and ZHP?
Sent from my SCH-I535 using Bimmer App
adamdifilippo is offline   Reply With Quote
Old 02-07-2013, 01:01 PM   #8
bigjae1976
bigjae1976's Avatar
The non-ZCPs use a smaller one piece rotor. Looks ugly. The ZCP use a much better and larger drilled floating rotor. Look cooler...girls love it
Old 02-08-2013, 06:57 AM   #9
adamdifilippo
My Ride: The M
Thanks for the info. I gotta do some research now because I am interested. Will the larger rotor fit on 18s? How much for. The rotors? And is there a big difference in stopping power?
Old 02-08-2013, 07:04 AM   #10
Brevik
My Ride: Tiag M3
Make sure to note these are from a ZCP M3 and not a ZHP 330
Brevik is offline   Reply With Quote
Old 02-08-2013, 09:54 AM   #11
adamdifilippo
My Ride: The M
Thanks for the heads up. That's my bad, I always get ZHP and ZCP confused. But I have a non-comp m3. Will be doing the research after work.
Old 02-08-2013, 10:11 AM   #12
bigjae1976
bigjae1976's Avatar
The front rotors are about $470/pr and they are 345mm. They do offer an upgrade in braking and heat. Not sure if they will clear OE18s. If they do..it will be close. I know they will clear a square set of OE18s (18x9s) because that's the wheel that was on the car when they were removed. Not sure about the front 18x8...probably needs a 12mm spacer.
I can add a pair 12.5mm spacer and stud/lug nut conversion for 2 wheels for $50. Or you can buy extended lugs.
Old 02-08-2013, 10:16 AM   #13
bigjae1976
bigjae1976's Avatar
Damn...Turner wants $3k for the 4 wheel upgrade. So with rotors, spacers, and studs...$225 + $470 in rotors = $700. Vs about $1.5k per axle? Is this a deal or what?
Old 02-09-2013, 07:29 AM   #14
bigjae1976
bigjae1976's Avatar
bump
Old 02-12-2013, 10:43 PM   #15
bigjae1976
bigjae1976's Avatar
Bump
Old 02-13-2013, 06:53 PM   #16
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
Free bump for the calipers.
Let me know if you'd sell the spacers and stud conversion.
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 02-15-2013, 10:32 AM   #17
bigjae1976
bigjae1976's Avatar
I'm using the SS lines. $160 shipped.
