Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 01-29-2013, 06:33 PM   #1
braehead
My Ride: 323i
Blower
Hi
First time posting got a problem with my 323I blower stopped working all the panel lights doing what should just no blower ?
John c
braehead is offline   Reply With Quote
Old 02-11-2013, 04:09 PM   #2
Jimbow
My Ride: E46 bmw
Hi mate it's the FSR it's called the hedgehog it's to the left where the clutch peddle is behind the plastic trim it's a nightmare replace. I did mine about 4 months ago it took me 2 hours i got my part from europarts. Search on here under hedgehog for step by step info
Jimbow is offline   Reply With Quote
Old 02-12-2013, 06:46 AM   #3
braehead
My Ride: 323i
Cheers
Had car in garage for over a week brought it out ,started it and blower starting working normaly then packed in after 5 minutes.
so hopefully it will be this part.
thanks again John
Old 02-12-2013, 07:11 AM   #4
Jimbow
My Ride: E46 bmw
I had the same problem with mine it would work then not work in the end it packed up. It's a swine do because there's no room to get your hands in.
Hope you get it sorted
Old 05-05-2013, 05:56 PM   #5
Jayp07
My Ride: E46 3.18i, E30 3.20i
I just replaced my FSR mate because i had an intermittent blower motor.... I made a video guide which should help as it can be a real pain, mainly because its awkward to get to but not technically difficult. Good Luck.
Jayp07 is offline   Reply With Quote
