2003 BMW 330Xi 5 speed/Manual Clutch/Gear Engagement Issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 01-29-2013, 07:52 PM   #1
kreaglewon
My Ride: E30,E39,E46
I am writing about a 2003 330xi 5speed that my girlfriend bought. She bought the car about a year and a half ago, drove it for 8mths and during that time we had no problems other than noticing that the clutch didn't engage until it was nearly completely released(Top end) expecting it needed a new clutch.
One day we got in the car and reversed out of a parking spot fine, switched gears into 1st to leave and the car did not go anywhere. I could release the clutch completely in 1st gear and you could hear something spinning like clutch chatter but, no
engagement/clamping force.
We had the car towed to a friend's shop and the clutch, clutch slave cylinder, and slave cylinder hose was replaced. They also checked the dual mass fly wheel and reset the auto adjust...(not exactly wha that's called but the flywheel was checked and reset)
The car drove fine for about two weeks until one day she drove it to work in the early morning (7:30isham). Got off work at 8pm went to leave after driving it in the am, nearly 13 hours previous. It was back to ambient temperature and the same thing happened as before, the car was in reverse/1st gear but, no engagement and the same clutch chatter (ChhhChhhChhhChhh...lol).
I had the car towed to my friends shop again and they pushed it inside while I was there with them inspected the lower exterior, lowered the lift and the car worked fine like nothing was wrong. This happens on and off/intermittent.
The shop and I have searched threads and forums about it and no one else has had any input. I'm really curious if anyone here has ever had this problem before or even heard of it happening...
kreaglewon is offline   Reply With Quote
Old 01-29-2013, 09:52 PM   #2
Kubica
My Ride: 2003 325xi
What was changed along with the clutch? Throw-out bearing? Why was the slave and clutch line changed?
Old 01-30-2013, 01:18 AM   #3
kreaglewon
A new clutch kit was installed which included the clutch plate,pressure plate and throwout bearing. The slave cylinder was leaking and the hose was bad.
When the symptom occurred the second time a new clutch kit was installed just in case the other was bad and the car still did the same thing.
Were now thinking about replacing the dual mass flywheel....although the tolerances seem to be ok. Gonna remove the transmission again tomorrow and investigate for at least the 4th time!
Old 01-30-2013, 10:59 AM   #4
Kubica
My Ride: 2003 325xi
If you are taking the tranny down again, replace #5,#6,and #7 too.
http://www.realoem.com/bmw/showparts...93&hg=21&fg=05
I would have a good look at the master cylinder first though. It sounds like it's sticking when you release the clutch pedal. The leaking clutch line is not normal. I would investigate further before taking down the tranny again.
Old 01-30-2013, 06:27 PM   #5
kreaglewon
Sorry, it wasn't the clutch line, it was the slave cylinder hose.
Old 01-31-2013, 10:24 AM   #6
chsu74
My Ride: 550XI,993TT,GL320
Is the clutch on these cars hydraulic? If so, does it run together with the brake line system? Has the clutch line been bled for air if engagement is inconsistent?
chsu74 is offline   Reply With Quote
Old 03-29-2013, 05:32 PM   #7
kreaglewon
Ok everyone here is the answer to the problem I was having.....
It was the aftermarket axel I bought. It didn't/will not seat completely. She drove it for several mths after I changed it, before the problem started. It was intermittently sliding out just enough to not allow the diff to engage properly. We just ended up getting a remanufactured OEM axel.
I would not recommend buying these...
http://www.fcpeuro.com/products/bmw-...5xi-bmwe46pair
Old 03-29-2013, 07:14 PM   #8
Somac
My Ride: 2001 330xi
Wow. Too bad you had to replace the clutch to figure that out.
Somac is offline   Reply With Quote
Old 03-31-2013, 03:15 PM   #9
kreaglewon
The car was bought used and we had no idea when the clutch was last replaced. Now we know for future reference and shouldn't have to worry about changing it again for a while...the glass is half full
Old 03-31-2013, 07:57 PM   #10
Kubica
My Ride: 2003 325xi
Never buy anything made in China for your E46.
Old 04-02-2013, 09:56 AM   #11
chilone
My Ride: 04 330xi, 97 Miata
Almost (if not) impossible.
chilone is offline   Reply With Quote
Old 04-02-2013, 12:07 PM   #12
Kubica
My Ride: 2003 325xi
Here we go with the idiotic comments.
Old 04-02-2013, 02:13 PM   #13
chilone
Oh no it's the hedge fund analyst's gopher. What are you doing on here? Run out of roofies and can't "bang" any more emotionally unstable children like you're so proud of doing?
Old 04-02-2013, 03:25 PM   #14
Kubica
My Ride: 2003 325xi
I'm here to remind everyone that you are a moron.
http://forum.e46fanatics.com/showthr...422&highlight=
Find the dishes yet? Lol.
Old 04-02-2013, 03:43 PM   #15
chilone
Hahahaha! According to kubica's tried and true infallible logic, if your car makes a strange noise that you can't figure out then you're a moron lol. No wonder this self proclaimed hedge fund analysts gopher can barely afford an E46. Any hedge fund analyst worth their salt should be in a brand new M3 at the very least.
Old 04-02-2013, 04:21 PM   #16
Kubica
My Ride: 2003 325xi
No, I actually took logic in college....I didn't see any in your last post.
You are a moron, so you think you have dishes in your dash, and aren't intelligent enough to find them. A noisy car does not make you a moron. You were born that way- that's why you sell inferior Chinese parts for a living.
Old 04-02-2013, 04:35 PM   #17
chilone
You wouldn't know logic if it hit you in the face. Go ask daddy for some more roofies. You need to get laid. You're pathetic.
Old 04-02-2013, 05:24 PM   #18
bmwbob89
My Ride: M-5 325 X3 528 740
Not to throw a wrench into a great discussion but. A lot of parts are now made in China. I order a Behr part and it says made in China on it. Everybody is cheaping out and subletting to them. So it will be real hard not to have a Chinese part in your fine German auto.
Those weren't even Chinese axles. Just crappy American ones. USA Industries
http://www.usaind.com/
bmwbob89 is offline   Reply With Quote
Old 04-02-2013, 05:29 PM   #19
chilone
Hey Bob. Yep, you and I live in the real world so according to kubica, we're idiots and we all know what an authority he thinks he is lol.
