Sponsored by BAVSOUND
Old 01-30-2013, 11:52 AM   #1
emm3speed
My Ride: 2005 m3
E46 M3 nav+ Hk .. Where to get input for the sub ? Remote/ground in trunk?
Basically I'm not all that familiar with what's under the carpet and panels in the trunk on my m3 and thought if ask before I go in blind to setup my amp/sub.
I know the battery is in the back so I'm hoping ill be able to wire everything within the trunk. Where would be a good location for the amp? Is there room under the panel on the floor in the trunk? Is there a good ground bolt anywhere obvious like a shock mount bolt maybe? Or should I wire the ground on the drivers side where the factory electronics are grounded? My car has the BMW TV option so there is a alpine unit on the tray above the battery.. Possible source for a remote Etc?
The big question is what should I use for the amp input? I have the line converter that turns into rcas into the amp but I don't know if I should use a speaker input from the factory subs pre or after amp Etc or rear speakers?
Tia
emm3speed is offline   Reply With Quote
Old 02-02-2013, 01:15 AM   #2
saxual328ci
My Ride: 2004 325ci
You can do a search for "how to put a subwoofer in a BMW 3 series" It will give several links on where to put everything.
saxual328ci is offline   Reply With Quote
Old 02-02-2013, 05:48 PM   #3
Arfboy
My Ride: 04 M3
Tia
If you're keeping the factory HK system and you're only adding an amp for a sub, then just tap into the harness before it enters the main HK amp on the driver's side for the input signal as well as the remote.
I just used the factory ground location on the driver's side as well. Just give the connector and the metal on the body a little sanding to make sure it gets good metal-to-metal contact.
Where you mount it is really entirely up to you and kind of depends on the size of the amp as well as the box setup for your sub. You can mount it to the back of a seat, to the box itself, to the floor, under the floorboard carpet, etc.
Arfboy is offline   Reply With Quote
Old 02-02-2013, 05:53 PM   #4
morningisbad
My Ride: E46 M3 Vert
Check out the bsw install instructions. Should tell you everything you need.
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
