Go Back   E46Fanatics > Everything Else > The Off-Topic > Food Talk
Food Talk
Do you like food? If so, you came to the right off-topic section. Discuss your favorite food topics here!
Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 01-30-2013, 02:12 PM   #1
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
Name some essential cookware
I just moved into a new place and literally have nothing. help me stock a kitchen.
also, where's a good place to go to buy such cookware? i don't need it to be masterchef-level expensive, but i'd like for it not to break after 2 uses either
Mike Larry is offline   Reply With Quote
Old 01-30-2013, 02:31 PM   #2
217Bimmer
My Ride: Dodge Durango
5 years ago i bought Emerilware set from Bed bath and beyond with a 20% off coupon because it is made by allclad, but at a terrific price. the stuff is awesome! nice and heavy duty, stainless for easy cleaning and durability, thick copper bottom for good conduction and heat retention and even cooking. set has about everything you need.
http://www.bedbathandbeyond.com/prod...p?SKU=17410750
additional things you should get are set of measuring cups, measuring spoons, liquid measurer, non stick square griddle pan, grill pan, non stick skillets, set of mixing bowls, a couple of cutting boards, cookie and baking sheet/pans, peeler, set of tupperware, collander, a nice set of cutting knives.
that should get you started and as you cook more and more you'll see what else you need.
** Political signature removed - Tim330i **
I always have to laugh when I see a thread described as "Not Work Safe." Is there anything on the OT forum that's really "work safe"? If I were your boss, I'd be mad if you spent any time on this forum at work at all. How is a picture of a naked girl any less work safe than, say, a picture of a matador getting gored in the *** by an angry bull? - VaderDave
217Bimmer is offline   Reply With Quote
Old 01-30-2013, 02:34 PM   #3
217Bimmer
oh forgot tongs and a container for your counter with all sorts of wooden spoons, spatulas, etc
Old 01-30-2013, 03:06 PM   #4
evolved
My Ride: 2011 BMW 335d
Bed, Bath & Beyond is going to be your best bet. They have mailer coupons that are typically 20-30% off of any item in store or even your entire order.
Present
2014 Jeep Cherokee Trailhawk V6
Past
2011 BMW 335d, 2011 BMW 135i, 2006 Mazdaspeed 6 GT, 2000 BMW 323ci, 2003 Evolution VIII, 1995 Nissan 240sx w/ SR20DET
evolved is offline   Reply With Quote
Old 01-30-2013, 04:35 PM   #5
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
thanks; i'm gonna do exactly that after work today. got my 20% off coupon ready
Old 01-30-2013, 04:38 PM   #6
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
do not buy emirilware
CALPHALON is the way to go
http://www.bedbathandbeyond.com/prod...p?SKU=14335803
VALMONT is offline   Reply With Quote
Old 01-30-2013, 04:43 PM   #7
217Bimmer
the one i have is actually the one below. you can see the copper layer. the one i posted earlier is actually the all stainless one i think and you can't see the copper layer. the one is more expensive than what i have, but i don't think it is much better. hopefully they have both and you can decide which you like better in terms of feel, types of pots included, and ergonomics.
an important consideration it to learn how to cook with this type of cookware. lower heat and being patient to let things heat up slower are big ones. not just turning heat on high and trying to get things going too fast. you can damage the cookware and will also ruin your food. avoid big temperature shocks, especially with the lids. don't run a flaming hot pan under cold water.
Old 01-30-2013, 10:26 PM   #8
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
i bought this.
http://www.bedbathandbeyond.com/product.asp?SKU=133188
i realize it's not a super-baller set, but it's good enough for my bachelorhood-style recipes. maybe once i get better at cooking, i'll invest in something nicer.
i need something that can withstand high heat to cook meat on now (i.e. sear a steak). recommendations? i was thinking cast iron skillet
Old 01-30-2013, 11:38 PM   #9
VALMONT
The De46vil's Army
VALMONT's Avatar
That's a good starter set.
Sent from my Nexus 7 using Bimmer App
Old 01-31-2013, 12:16 AM   #10
Fisch330ciTopasBlau
Yes...I do think I hate you
Fisch330ciTopasBlau's Avatar
My Ride: A car.
BB&B is pretty good to go look at ****. Of course you can head over to Williams Sonoma or a specialty kitchen store too.
I have a set of Calphalon Non-Stick cookware, smaller than the set that Valmont linked to.
http://www.bedbathandbeyond.com/product.asp?SKU=104198
Mine is in a different finish that they don't offer anymore, it was a matte grey finish.
I also have a couple deep sided All-Clad stainless pans that I've picked up over the years.
Add in a cast iron pan or two, can't go wrong with one made by Lodge.
For normal small appliances I like Breville, Dualit & Kitchenaid.
You may want a rice cooker, slow-cooker, sous vide cooker, deep fryer, espresso machine, etc.
-8/21/2007 RIP Grandma
-pessimum genus inimicorum laudantes: flatterers are the worst type of enemies
Fisch330ciTopasBlau is offline   Reply With Quote
Old 01-31-2013, 11:10 AM   #11
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
would my steaks turn out crappy if i used a stainless steel pan to cook it? on the one hand, i'd like a cast iron skillet to cook the steaks on, but i wouldnt have any other use for said skillet. if i bought a stainless steel pan, i could use it for a number of other stuff (e.g. chicken, fish, stir fries, etc.)
Old 01-31-2013, 11:18 AM   #12
auto180sx
My Ride: '02 Steel Blue 330Ci
Cast iron pans are cheap, no reason not to have one. I think mine was only 15 bucks, and I use it for a lot more then searing steaks; it's probably one if the most used pieces of cook wear in the kitchen.
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 01-31-2013, 11:18 AM   #13
217Bimmer
nice set, i wouldn't have recommended a non stick set for everyday use, but the newer ones hold up better.
a grill pan can be used for a lot of things. i have a grill pan like this
and also just got this griddle/grill from lodge
on the grill side you can do steaks, chicken, pork, kabobs, veggies, whatever you can do on a grill.
the griddle i just made some bomb ass fajitas and use it for pancakes, eggs, grilled cheese, etc
main thing is knowing how to clean and season it properly. again using lower heat and preheating properly is the key! if you want more versatility then go with the griddle that has both sides.
Old 01-31-2013, 11:27 AM   #14
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
^you're supposed to use low heat for things like that? i thought the whole point was that it could withstand insanely high heat so you can get a good sear going on your meat
Old 01-31-2013, 11:38 AM   #15
smares21
My Ride: M3
If you have a costco business center near you, that's your best bet. Regular costco membership will get you in. They have a huge section designed for restaurants. Good quality, low price. I get my BBQ tongs there. $2.29 for the 24" tongs. Soup ladels are about $3. etc. Just basic stainless steel quality stuff.
Clarkson on the 1M: "There's a straight six engine at the front, a manual gearbox in the middle, and drive goes to the back. That's page 1, chapter 1 from the petrosexual handbook."
smares21 is offline   Reply With Quote
Old 01-31-2013, 11:44 AM   #16
217Bimmer
i wasn't too clear. by that i meant that you don't just put it on high heat. you can damage it or crack it in half or burn your food. medium or medium high is plenty high and let it fully come to temperature. main thing is to BE PATIENT! they can withstand extremely high heat, but not temperature shocks.
Old 01-31-2013, 11:55 AM   #17
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
ohhh i see. so it can build up a lot of heat, but you're not supposed to just take it from the cupboard and stick it onto high heat? i've been doing that for years to my old cookware, which is probably why it all got ruined and i had to throw them out when i moved out of my old place. i've decided that i'm gonna be more cautious about this type of stuff this time around lol
Old 01-31-2013, 12:04 PM   #18
217Bimmer
EXACTLY! people are just impatient and put stove on high and want to cook right away and it warps and cracks cookware and non stick coatings come off.
your food will cook better and more evenly and your cookware will last much much longer that way.
Old 01-31-2013, 12:24 PM   #19
smares21
My Ride: M3
I have the griddle/grill piece also. I use it all the time. Makes for great char marks on asparagus.
If you get a nice 12" cast iron skillet (I have the lodge logic one too), you can make epic restaurant quality steaks on it. I use this recipe all the time. http://bbq.about.com/od/steaks/ss/aa071507a_4.htm
Old 01-31-2013, 01:01 PM   #20
217Bimmer
oh hell yeah, i love cooking on cast iron. asparagus is my favorite grilled vegetable, usually outside, but can do on my grill pan.
thanks for the great steak recipe. that's how they should be done inside! we need a cast iron cooking thread!
