Old 01-30-2013, 05:49 PM   #1
BavarianBorn
My Ride: 2005 3.30i ZHP
How to Update E46 DME with NCS or WinKFP? DIY?
Hi All,
This may seem like a simple question, and there is a lot of information out there, but does anyone have a straightforward DIY on flashing the DME using my Vag-Com cable & NCS expert or winkfp? I have INPA functional.
I have read that I will want the V41 Daten files, and that will use the ms45.1 profile for my 2005 zhp.
I've found where to download the v41, and how to drop the e46 updated daten files in my NCS editor folder.
From there do I just need to open NCS Expert, read / retrieve vehicle information (ZUSB) and all of my modules in expert profile, leave everything unchanged (no manual adjustments at this time), and write them back to the DME?
Will that properly apply the V41 updates to my DME & other modules?
Terra recommended using winKFP but I'm having trouble finding definitive DIYs for either. Any help is much appreciated.
BavarianBorn is offline   Reply With Quote
Old 01-31-2013, 01:13 AM   #2
vitaladeel
My Ride: 2001 BMW 330ci
Yes can anyone answer this please
Sent from my SPH-L710 using Bimmer App
vitaladeel is offline   Reply With Quote
Old 02-03-2013, 01:57 AM   #3
HakenTT
My Ride: 323i with S54
Problem is that it is hard to set up the free internet version of these factory files to some cheap VAG cable.
There is a company that sells software with matched cable, installs it properly and it works :
bmtechnic
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 02-05-2013, 02:39 PM   #4
karitammi
My Ride: 325 (E46) Cabrio
Well this is far from solid DIY, but:
- Install BMW standard tools, this is rather good thread http://bmwcoders.com/forum/bmw-gt1-o...-software-328/
- Or this guide, showing how to configure the port in Windos devide manager for K + D CAN http://www.6buys.com/ebay/doc/InpaCANinstall.pdf. Remember to check OBD.ini and Inpa.ini accordingly.
- To import E46 daten in WinKFP http://www.sfischerdesign.com/pdf/Ho...art_WinKFP.pdf. BUT BE AWARE WITH STEP 8. For my E46 daten, it didn't work in that way. I skipped step 8 and did NOT overwrite the files and it worked without cutting any lines.
Then for updating the DME in WinKFP. You can either go for certain desired ZUSB number or select update ZUSB to get the newest one. Then selectt program. Terra has explained this in many forums, he'd be the best to answer.
Hope this helps a little.
karitammi is offline   Reply With Quote
Old 02-05-2013, 04:55 PM   #5
Guest021715
Account closed.
Search OBD USB Diagnostic thread in General, if you can't find what you need in there - you're looking for the wrong thing.
I wrote up a DIY there. These subforums are usually dead.
Old 02-05-2013, 06:38 PM   #6
phubar
My Ride: 335is, HD
FYI I've never been able to get winkfp to work other than 5.1.6, the version included with most INPA installs have never worked for me, the problem with 5.1.6 is if u install it after INPA then your config gets all messed up, so backup ur inpa.ini file. but I like to nitpick so I just formatted my tuning tablet and installed everything from zero in this winkfp 5.1.6 then INPA.
I would uncheck all UIF settings in winkfp so it doesnt alter ur flash count if u r wanting to try different files.
phubar is offline   Reply With Quote
Old 02-06-2013, 01:10 AM   #7
karitammi
I got INPA 5.0.2 and WinKFP 5.1.6. It felt hard to get them all installed properly.
Originally Posted by phubar View Post
...I would uncheck all UIF settings in winkfp so it doesnt alter ur flash count if u r wanting to try different files.
Can you please elaborate this? What you can do if you uncheck UIF? And no limit of about 10 flashes anymore?
Old 02-06-2013, 05:50 AM   #8
Guest021715
Account closed.
Unchecking UIF writes means you don't use up of one of your flash counts. The DME will report as if you still had your old software version, but be running on the new one.
Old 02-06-2013, 08:44 AM   #9
karitammi
Very good to know. Thanks a lot!
Old 03-15-2014, 10:31 AM   #10
Tac330
My Ride: 330ci & 98 750il V12
Send a message via ICQ to Tac330
can anyone please send me a link to v41 daten files for e46. i have tried countless links where i need an account or it just wont work
2003 330ci ZSP DTM Fiberwerks OnepieceLip, BC Racing Coilovers, Headers, ZCP M3paddle shifters, Eu2
Tac330 is offline   Reply With Quote
Old 04-03-2014, 12:16 AM   #11
BartenderPlease
My Ride: '03 540i/6 M-Sport
same
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 06-14-2014, 03:25 PM   #12
HAMMER377
My Ride: e46 m3
I have managed to find all the daten files on another site hope this helps!
http://www.m5board.com/vbulletin/e63...ol-free-4.html_nr_
HAMMER377 is offline   Reply With Quote
Old 04-13-2016, 02:58 PM   #13
Bigraze
My Ride: E46 sedan
Sorry to bring up a old post but i am trying to find the link to update my computer does anyone have it and also what kind of cable can i use?
Bigraze is offline   Reply With Quote
Old 04-30-2016, 01:00 PM   #14
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Steps to Update ECU using WinKFP
Open WinKFP.
Click "Comfort mode".
Click "Update ZUSB" and you get a box displaying ECU families.
Choose your ECU family (MDS42 for MS42, MDS43 for MS43, MDS451 for MS45.1, etc.), click Ok.
Click "Done", which goes back a screen.
Click "Prog ZB-Update", and you should get a box that displays your current ECU version and suggests an update version.
Click "Yes" and you get another box asking permission to program ECU.
Click Ok and the update begins.
It takes about 10-15 minutes to complete for MS42/43, 45 minutes for MS45.1.
At the end it tells you that the programming was okay.
Reset adaptation values using INPA or PA Soft after it is done.
You can see screen shots and more details starting at post #4 in this thread.
http://www.bimmerforums.com/forum/sh...4#post21164324
///Mmmmmm...
Old 06-30-2016, 11:42 AM   #15
Georg
My Ride: 330 with ms42
the cheapest K-line usb adaptor can be used
Georg is offline   Reply With Quote
Old 06-30-2016, 12:51 PM   #16
BaliDawg
Get this package:
http://www.ebay.com/itm/231781224487...%3AMEBIDX%3AIT
It includes the cable, software, a good installer, and tech support.
Note that you will need to connect pins 7 and 8 together on the OBD cable, or buy an adapter that does that.
///Mmmmmm...
Old 07-04-2016, 12:22 PM   #17
Robotpants
My Ride: 2000 323i Touring
How's that done?
Robotpants is offline   Reply With Quote
Old 07-04-2016, 08:28 PM   #18
BaliDawg
Originally Posted by Robotpants View Post
How's that done?
Solder the pins, or wire them together, or buy the adapter I mentioned.
///Mmmmmm...
Old 12-13-2016, 04:43 PM   #19
GreatFrog
My Ride: 03' 330i ZHP, 07' Z4
Use WinKFP 5.3.1 or 5.1.6, just don't use 5.1.0. It failed on my randomly.
2005 325i ZSP [SOLD]
2007 Z4 3.0i
2003 330i ZHP
GreatFrog is offline   Reply With Quote
Old 03-27-2017, 11:38 AM   #20
MTX-4
My Ride: E46 320i
I'm sorry to dig this old thread up. But I have run into an issue after installing WinKFP 5.3.1
I have INPA running ok. Following the instructions available online, I've imported the SGDA (.IPO files), ECU (.PRG files) and assembly line data. After choosing "Comfort Mode" -> "Update ZUSB", there is nothing on the "ECU family". It's empty.
Did I import the files incorrectly?
MTX-4 is offline   Reply With Quote
