Sponsored by BAVSOUND
Old 10-31-2012, 04:03 AM   #1
cityjohn
My Ride: 2001 M3
+12V switched available in trunk?
Anyone know if among all the existing wiring there can be found a switched 12-volt supply inside the trunk? In other words, I can tap into it and it will be ON whenever the ignition is on but OFF once the key is removed. Thanks for any help!
cityjohn is offline   Reply With Quote
Old 11-02-2012, 09:02 PM   #2
cityjohn
My Ride: 2001 M3
Old 11-02-2012, 09:28 PM   #3
benzovs
My Ride: 2000 323i
The remote turn on for the amp is a 12v + switched..... HOWEVER... I'm not sure if it's ignition switched or radio switched. You would have to use a relay to bump up the current if you are powering up anything that draws more than 500ma. I'm pretty sure there is at least one more 12v switched source in the trunk, just not certain of it.
benzovs is offline   Reply With Quote
Old 11-02-2012, 09:56 PM   #4
cityjohn
My Ride: 2001 M3
Thanks benzovs! I will take a look at that.
Old 06-27-2014, 08:02 AM   #5
cityjohn
My Ride: 2001 M3
Still hunting for this wire if anyone knows. I traced it to a "purple" wire but couldn't see that it was on-with-ignition.
Old 06-27-2014, 08:29 AM   #6
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
the one mentioned above, the amp turn on wire, is white and can be tapped at the amp.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 06-27-2014, 09:56 PM   #7
cityjohn
My Ride: 2001 M3
^ Thank you; I will try it
Old 06-28-2014, 08:18 AM   #8
markusmarkus
My Ride: 2001 330Ci
I don't believe that there's any switched 12 volt wire in the trunk. The remote turn-on is for the amp, but a) it has very low current capability, and b) it's only only when the head unit is on.
The solution is to run a switched line from the dash to the trunk. Depending on the intended current load I'd install a normally open relay. The wire from the dash, when activated, would energize the relay coil. One of the relay's contacts would go to the battery and the other contact to the load.
