Old 02-01-2013, 01:54 PM   #1
metrocpa1
My Ride: 325it
help! - part of the wiring harness
Car: 2003 325iT manual trans M54
I'm cleaning my engine and replacing some things; needed to take the intake off to get to everything easier. While doing so, I ripped the wires from one of the plugs (part of the wiring harness). It's mounted on the drivers side rear of the engine, just below the starter. I checked on realoem and I can't even find it...or figure out what this is for.
IMG_2548
IMG_2549
two questions I'm hoping someone can help me with:
1) can you tell me what holes of the plug the wires go into? Red, Yellow and Brown. The plug holes are marked 1, 2 and 3 but I don't know the order. Have a photo?
2) If I can't fix it myself, what does this control? Is it really needed?
Trying to avoid the purchase of an entirely new wiring harness if I can avoid it.
Help is appreciated!!!
Scott
metrocpa1 is offline   Reply With Quote
Old 02-18-2013, 02:55 PM   #2
metrocpa1
My Ride: 325it
Any insight on this? I'm going to have to "guess" or get a whole new wiring harness
Old 02-18-2013, 03:06 PM   #3
xxxxxbrianxxxxx
My Ride: 2007 328i sedan
doesit still run if it does then it could be abs or traction control but i hope someone can help you i dont know much on the 325
xxxxxbrianxxxxx is offline   Reply With Quote
Old 02-18-2013, 04:10 PM   #4
dslboomer
My Ride: 2001 BMW 330I
Scott
Ha-ha, You think BMW put a stuff there for no reason?
I think it is a connector for the crank shaft position sensor.
I can not find actual listing by the pin numbers, but normally three wire sensor connector has following scheme:
Power: red: pin 3
Signal: yellow: pin 2
Ground: Brown or black: pin 1
Compare above with camshaft sensor connectors because they are basically same type.
dslboomer is offline   Reply With Quote
Old 02-18-2013, 04:15 PM   #5
RKiepper
My Ride: 1999 E46 328I x2
If its wiring that goes below where the starter is, I'm gonna say its the oil level sensor...
If its not that, then the fuel pressure regulator sensor.
RKiepper is offline   Reply With Quote
Old 02-18-2013, 04:16 PM   #6
cyberkaa
My Ride: E46 332i,M3;E30 325i
Yes, that's the crank position sensor.
You can repair the harness. You'll need to buy the weather sealed bushing contacts and possibly a new plug housing if you can't extract the old contacts.
-Kalim
(klx photo studio)
