Old 02-01-2013, 04:08 PM   #1
trentcdrums
My Ride: BMW 323i Sedan
Done with this car! EML, Traction light, CEL back again!
The title states it. I have cleaned my throttle body, ICV, replaced intake boots and cleaned, changed spark plugs. The dealership said the reason this was last time was because I had a bad valve cover. So I spent $500 on that replacement and it was great for months. Now it's doing it again.
I am drumming a huge youth retreat 2 hours away and had to pull over "12" times because the car wouldn't let me go over 45 mph! So I turn the car off and on again. The cel stays on but the eml and traction lights are off. Every stop sign I approach, the lights comes back!
I know there are multiple threads on this. But I am wondering if maybe y throttle body is done for or my icv.
Here are the codes.
P1510 -ICV STUVK
Old 02-01-2013, 04:10 PM   #2
trentcdrums
Sometimes it gives more than one code. Thanks for helping fanatics!
Old 02-01-2013, 04:14 PM   #3
trentcdrums
ICV stuck**
Old 02-01-2013, 07:06 PM   #4
trentcdrums
Anyone?
Old 02-01-2013, 07:08 PM   #5
My Ride: Lexus
Some have reported that as being caused by an intake cam sensor failure. but it does seem to happen more frequently to 323s. search around!
Old 02-03-2013, 04:20 PM   #6
trentcdrums
Well two days later after not driving the car. I drive it today 2 hours home, no issue until the road stretch to my home the same thing happened again. So everything must be good except the computer or sensor. Ideas?
Old 02-03-2013, 05:05 PM   #7
Zchild
My Ride: 2000 BMW 3XXi ZSP
Have you checked the O-ring on your DISA valve; just a thought...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 02-03-2013, 05:09 PM   #8
WDE46
My Ride: '13 128i, '04 330Ci
I'm going with Mango's theory of position sensors. Hell, I'd just buy all three (exhaust/intake cam, crankshaft).
Old 02-03-2013, 05:32 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by trentcdrums View Post
ICV stuck**
Whatever you did to the ICV did not work.
Just because you touch something does not mean it will be cured. They say Jesus fixed stuff that way, but I don't recall anybody else doing that. I sometimes fix stuff and have no clue what I did, but if something does not work and it still does not work after I fix it, then my assumption is that I did not fix it. I don't carry on as if there is something else wrong, I assume the same thing is still wrong, ESPECIALLY when the car is telling me the same thing is not working.
If the car insists that the ICV is stuck, then it's a pretty safe bet that the ICV is stuck.
Old 02-03-2013, 06:11 PM   #10
Zell
Zell's Avatar
My Ride: so turbo wow
Replace the ICV rather than clean it. Also, when you cleaned it, what did you clean it with? You should have used something that also lubricates the part as well. Seafoam Deep Creep does this.
Old 02-03-2013, 07:55 PM   #11
trentcdrums
I have used carb cleaner, sea foam, wd40...
Old 02-03-2013, 07:59 PM   #12
trentcdrums
Yeah I actually replaced my exhaust side two weeks ago!
Old 02-03-2013, 08:34 PM   #13
trentcdrums
Can a bad o ring in the DISA cause that? I do remember always seeing a gap in there!
Old 02-05-2013, 08:13 PM   #14
trentcdrums
Praying that I found the problem and this will all be over in just a few minutes. Advanced auto parts had the ring that I needed for replacement! Only $1.10! Attachment 489493
Attachment 489494
Attachment 489495
Old 02-05-2013, 08:57 PM   #15
jfoj
My Ride: 330CiC, M5, X5, E93
Time to start and read the first link below in my signature.
Its pretty hard to hook the O-ring on the DISA but it did happen.
Might as well check the DISA out fully and go over some of the other basics as well?
Not sure this will be the cause of your problem, but you never know.
Good luck.
Old 02-05-2013, 09:24 PM   #16
trentcdrums
Good luck.
I got the idea from your signature as it is through a Google search. Thank you very much man!
Old 02-05-2013, 10:02 PM   #17
ryannel2003
My Ride: '04 Cadillac Deville
The DISA isn't the problem. Either you need to replace your throttle body or your ICV. My 323 did the exact same thing the week after I bought it and I cleaned the throttle body and it hasn't ever come back. I also cleaned the ICV at the same time too and the car was much nicer to drive.
ryannel2003 is offline   Reply With Quote
Old 02-05-2013, 10:08 PM   #18
trentcdrums
I guess why I struggle to believe if either are bad is because one day I'll drive and no problem. And a week later the problem comes for a day a then stops for a while. It's random times.
Old 02-05-2013, 10:10 PM   #19
ryannel2003
Mine also did that. Cut the car off and it was fine and drove for a few hours with no problems. Next day it was back on and I couldn't go above 2k RPM's and 50MPH.
Old 02-05-2013, 10:32 PM   #20
trentcdrums
Exactly what I am experiencing. Do you know if seafoam is safe to clean electrical connections? It looks like my connection and input on my disa valve is Brown inside.
