#41 | |
#42 | |
#43 |
So I cleaned the electrical connections on the ICV and ordered a $35 recycled one from Bavarian Recycle in Cali so I hope this solves the issue. I've cleaned this ICV 4 times already. One question. Have they cleaned the one ordered or did they just take it and sell?
#44 |
The card idle was rough again today as well. So I opened the hood and hit my hand able to unhook the ICV electric plug and so I did. The cars idle seems easier but rough still obviously because it has no control. I looked to see what the dash was giving and the EML AND TRACTION WAS ON, just like it does I'm driving at the car does it limp mode. I noticed change after unplugging. So luckily yesterday I ordered an icv from Bavarian Auto for $41 shipped used. Hoping for this to all be over and to not be scared to let off the pedal and see the EML, and travtion lights.
#45 |
EML/traction/CEL light happened to me twice. your car is probably running in "safe mode" on two cylinders. do you only have like 2 forward gears and does your car sound like a vacuum cleaner thats clogged?
#46 | |
You could get a brand new OEM Bosch ICV for $118 at Amazon. http://www.amazon.com/Bosch-02801405...ds=13411744713 You could cancel that order, and just buy a brand new one for $70 more, and be sure that you have fixed the issue. I don't think you will find an OEM Bosch unit for less, but I may be wrong. The pricing for these things is all over the place. The next lowest price I found was $154, and I have seen them priced as high as $255. I would be seriously pissed if I paid that much for one. But it is an electro-mechanical part, with a valve that opens and closes to allow additional air into the intake, and a motor that controls the valve. It basically is a modern version of a choke. The motor can fail, and the valve may not move correctly over time. There has to be some sort of bushing/bearing for that valve to pivot on, so the whole thing could get sloppy and not move as accurately as it wears out. It is not designed to be serviceable at all. Since it is a sealed unit, it is almost impossible to clean the entire thing correctly, while at the same time lubricating the mechanical parts of the valve, and keeping the electrical motor clean. It is simply not possible to get a good look at the internal mechanical parts, and look for signs of wear. Who really knows what is an acceptable amount of mechanical slop in the actuation of the valve? Think about how hard it would be to verify that a DISA valve was functioning properly, if it was a sealed unit, and you could not see if the flap was opening and closing properly. That is basically what this is, only smaller. I paid $105 for one from Amazon about a year ago. I could have cleaned mine again, but I just wanted to have a new one, instead of wondering if it really was functioning as well as it should be. If they all cost $250+, I may have cleaned it out for a while longer, but for around $100, I decided to just replace it. I really want to slice the old one open, and see exactly what is in there, and get a good look at the internals. I could not find anything like that on the Internet. Good luck! Edit: here is the same part, selling for $300 on eBay. http://www.ebay.com/itm/13411744713-...-/110793218061 Last edited by MJLavelle; 02-16-2013 at 03:08 AM. |
#47 | |
#48 |
No I don't believe
#49 |
I talked to a local enthusiast about whether I should just use the used ICV or get a brand-new one. He did state that my car is very old and has a lot of mileage, so it would probably be worth the last cash to not spend so much money on it as I could buy a brand-new one in the future. Hopefully the company is a good company to buy from, and if not, I hope the part messes up between my six-month warranty.
#50 | |
#51 |
I sure hope is not the throttlebody. That would be an expensive and on fun job. I will definitely keep updates, but I have cleaned the throttlebody, boots, and ICV multiple times and still have no luck with it. The car is old with 170,000 miles on it
#52 |
I'm not familiar with the 323i but do you know if your TB is mechanical or electrical?
EDIT: More then likely it is a bad ICV but if that doesn't resolve the issue then it is either the whole EDK throttle body or the TPS sensor on the MDK throttle body depending on which TB is in your car. Last edited by 2003silver330i; 02-16-2013 at 09:20 PM. |
#53 | |
#54 |
I have a mechanical!
#55 |
This is a generic version of how to test a TPS:
http://www.ehow.com/how_5832553_chec...on-sensor.html |
#56 | |
#57 | |
#58 |
Keep us informed. I have posted in 3 or 4 threads and have talked to people who all have this same problem. We scan for codes and it shows that our icv is stuck open. Some of us replaced the icv but had no luck. We are all trying to figure this one out but still cant find a solution after months of trying.
Someone showed me a thread were a member had this problem and his mechanic fixed it when he found out one of the wires going to the icv was bad. I am currently trying to figure out if my wires are bad but not sure what the correct voltage should be.. Last edited by Dippinwandy; 02-17-2013 at 01:39 PM. |
#59 |
Here
#60 |
A bad crankshaft sensor "can" cause bad idling and acceleration behavior. You can give that a shot.
