Old 02-01-2013, 07:01 PM   #1
slimg00dy
My Ride: E46 325i
E46 325i Halogen to HID upgrade.
Hi, I've got a 2002 E46 325i and I'd like to upgrade to HIDs.
I'm currently looking at these. http://www.amazon.com/2002-2005-Blac.../dp/B005EM8BAK
I don't know if anyone has any experience with them or anything.
Also I don't know if there is any DIY for it, I keep finding "retro" fitting ones but I'd rather just do a plug and play.
Cheers.
slimg00dy is offline   Reply With Quote
Old 02-01-2013, 07:03 PM   #2
FrodoTBaggin
My Ride: 2004 325i
Holy **** that's expensive. Are there cheaper options?
FrodoTBaggin is offline   Reply With Quote
Old 02-01-2013, 07:08 PM   #3
willsbma
My Ride: 99 323i
If you want "plug & play" go OEM. You won't find anything close in the aftermarket arena. Depo is the closest one and everyone here says they still suck. Your best bet is the retrofit for I believe around $200
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 02-01-2013, 07:28 PM   #4
slimg00dy
My Ride: E46 325i
-_- I was hoping I didn't have to go that route, I did find this DIY quite easily http://forum.e46fanatics.com/showthread.php?t=840919 Looks pretty cheap.
Old 02-01-2013, 07:35 PM   #5
choxor
My Ride: JDM
Depos. Are. Garbage.
Search for projector retrofit.
Old 02-01-2013, 07:55 PM   #6
WDE46
My Ride: '13 128i, '04 330Ci
hahahahaha
Old 02-01-2013, 08:34 PM   #7
willsbma
My Ride: 99 323i
This is exactly what you should do if you want decent pj's
otherwise go OEM
Old 02-01-2013, 08:37 PM   #8
GATORSHOES2
My Ride: 2002 BMW 325i
Couldn't you find some off a wrecked E46 and use them?
GATORSHOES2 is offline   Reply With Quote
Old 02-01-2013, 09:13 PM   #9
Commando
My Ride: '02 325Ci MT '04 M3
Whichever brand you choose you will need to install projectors. Those little TRS projectors you mentioned at the start work well although there is still a bit of reflector cutting. There are many many threads covering this and there are many projectors which give a better result than the OEM items. Once you go HID you won't want go back to 'ordinary' halogens again.
Don't be tempted to do the H7 HID replacement. Also the 4300ēK does work out best.
Commando is offline   Reply With Quote
Old 02-01-2013, 09:18 PM   #10
sunsetcoast
My Ride: '99 323i & '00 323iT
If you want plug and play HID, the easiest route (and best quality, by far) is to source a set of used OE lamps. You won't likely find both sides in the same place, but figure roughly the same money as the units in your link. Installation is 30 mins. Your dash indicator may light up until you get a recode (from a dealer, indie, or list member), but the lights will work just fine.
sunsetcoast is offline   Reply With Quote
Old 02-01-2013, 09:58 PM   #11
Adrianmgb
My Ride: 2002 325i
Cheers.
This is expensive...if you're gonna spend this much might as well get an oem bi xenon projector headlight....
Adrianmgb is offline   Reply With Quote
Old 02-02-2013, 04:57 AM   #12
choxor
My Ride: JDM
You do realize you bought a BMW. If you want cheaper options buy a Civic.
But yes, retrofit will be cheaper.
Old 02-02-2013, 07:43 AM   #13
FrodoTBaggin
My Ride: 2004 325i
I'm fully aware that I bought a BMW, friendo. Ironically, I traded in an 06 civic sedan with 20,000 more miles than my Bimmer, as an even trade. $500 just seemed steep from other things I've read here. Should have said "aren't" instead of are in my initial post.
Old 02-02-2013, 01:03 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Click on projector retrofit in my sig and do that
Old 02-04-2013, 09:02 AM   #15
slimg00dy
My Ride: E46 325i
Thanks, I've decided to do the retro fit. I'll post up my results when I'm done.
