Old 02-23-2013, 10:33 PM   #41
440duster
My Ride: 2003 325i TS1
That's What I think too. What is the open port on the back of the blower? It is around 3/4 inch. I'll start pulling it off tomorrow night. What should I do about a gasket?
440duster is offline   Reply With Quote
Old 02-23-2013, 10:36 PM   #42
lab rat
My Ride: '02 330iT
that's where the IAT goes if your car is MS43. If you have MS45 then you need to transfer the dead plug from your intake.
Because sleeper
Old 02-23-2013, 10:38 PM   #43
440duster
I'm dumb. I'm at dinner now, I'll post back when I get home and transfer the plug. Thank you
Old 02-23-2013, 10:41 PM   #44
lab rat
My Ride: '02 330iT
The ESS install guide is dumb. I spent 2 weeks troubleshooting the same problem
Because sleeper
Old 02-23-2013, 10:43 PM   #45
440duster
Where is the plug located?
Old 02-23-2013, 10:48 PM   #46
lab rat
My Ride: '02 330iT
On the original intake manifold it's in the middle between runner 3 and 4. The installation manual has a pic of MS43 manifold that has the IAT sensor in this location.
Because sleeper
Old 02-24-2013, 12:53 AM   #47
440duster
Problem solved. Car runs great!! Pulled off the transmission and blower install in 9 hours (not including tear down). Thanks lab rat, ess should make a point to provide a plug as mine is damaged now from ten years of staying put. Will order a new one Monday. Headers Also come in Wednesday so a bit more work to do.
Old 02-24-2013, 01:23 AM   #48
Japanrot_325i
My Ride: 03 325i
Awesome build. Can't wait to see how the finished product performs.
Japanrot_325i is offline   Reply With Quote
Old 02-24-2013, 03:15 AM   #49
440duster
I haven't ridden it too hard yet as I have to baby it for 100 miles, but I can't wait, I love the whine. I need to get an ssk, the OEM is quite long.
Old 02-24-2013, 10:06 AM   #50
lab rat
My Ride: '02 330iT
Yeah, I gave ESS hell for making crappy install manual. The section about IAT sensor is clearly marked as MS43 only so someone with MS45 is gonna skip it. It does have tiny note about the dead plug there.
Start with the ZHP shiftknob. It shorter than stock and made enough difference for me.
Because sleeper
Old 02-26-2013, 08:53 PM   #51
440duster
Here are some pictures of the finished install. It runs pretty good but the idle hangs around 1200 rpm before dropping down to normal. Not sure if it's the tune or if something else is going on. No codes. Headers and full exhaust this weekend.
ID:	492766   Click image for larger version
ID:	492767   Click image for larger version
Old 02-27-2013, 04:54 AM   #52
paraklas
My Ride: ESS TS2 320ci
Congrats! Mine only idles at 1100 when the engine is very cold. Then it slowly settles to 650ish. I have also e-mailed ESS (Hans) a few minutes ago about a solution that I'm thinking to prevent oil vapors going back into the intake manifold but instead draining back to the sump.
Old 02-27-2013, 12:39 PM   #53
lab rat
My Ride: '02 330iT
I think there was someone with twinscrew using the BMW performance oil separator.
Because sleeper
Old 02-27-2013, 02:24 PM   #54
440duster
My headers showed up today, too bad I work thru Saturday. I get my ATI epod on Friday. Not sure if a mechanical boost gauge will fit in the pods. Does anyone have experience fitting one?
Old 02-28-2013, 11:12 PM   #55
440duster
ESS told me today the idle speed is adaptive and stays a bit higher at first to prevent stalling due to the extra load from the blower. Headers got dropped off for ceramic coating today, 160 for both.
Old 03-03-2013, 10:03 PM   #56
440duster
Headers go on tomorrow. Tonight a B7 Audi S4 was messing with me. We did a pull from maybe 40 mph, my front bumper was right next to his rear tire. Pretty impressive that I hung with him considering it is a 340hp 302ftlb car.
Old 03-04-2013, 11:02 AM   #57
lab rat
My Ride: '02 330iT
340 minus the AWD drivetrain loses is probably 250-260whp.
My m54b25 with TS1 pulled 243whp on a mustang dyno.
Because sleeper
Old 03-04-2013, 11:13 AM   #58
440duster
Ya those ratings are crank numbers. I was still impressed though
Old 03-04-2013, 03:11 PM   #59
lab rat
My Ride: '02 330iT
So now that you went from NA b25 to TS1 imagine similar performance gain when you go for b30 TS2
Because sleeper
Old 03-04-2013, 07:36 PM   #60
440duster
I'm pretty happy. But I find myself looking at used motors already... we will see how long it takes.
