Sponsored by BAVSOUND
Old 02-02-2013, 04:30 AM   #1
steveintheburgh
My Ride: 2004 330Ci
12V under steering wheel?
Looking to hardwire a Garmin to be mounted left of the cluster.
I've read that the ignition wire (green) has too much juice?
Anyone know off hand where to tap in?
I know brown is ground....
If no specific advice...I assume I can just go under there w/ a multimeter and find a hot wire w/ the key in position 1...no?
Is there anything I should NOT tap into?
Sorry for the ignorance...not an electrical guy.
steveintheburgh is offline   Reply With Quote
Old 02-07-2013, 06:13 PM   #2
steveintheburgh
My Ride: 2004 330Ci
Bmp
Old 02-07-2013, 06:14 PM   #3
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
why not use the lines to the cigarette lighter in the ashtray?
VALMONT is offline   Reply With Quote
Old 02-07-2013, 06:21 PM   #4
steveintheburgh
My Ride: 2004 330Ci
I'm mounting the nav in the bottom Left of the windshield....thought under the steering wheel would be closer---plus easier to get to.
Old 02-07-2013, 08:00 PM   #5
invictus
My Ride: M3 (F80 & E46), S3R
I tapped the 12v on the ODB port to power my traqmate. It's on the left side.
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 02-13-2013, 01:00 AM   #6
Halston@BSW
My Ride: E30 X5 TJ
In most BMWs a white or purple/white stripe will be switched power. Somewhere under the steering wheel you should be able to locate a wire that fits and will provide what you need. Always test with a meter just to make sure of course.
Halston Pitman
rhp@bavsound.com | ext. 104
BSW | Audio Solutions for YOUR BMW
www.bavsound.com | 404-963-8857
iPod Integration | Plug & Play Speakers | Subwoofer Solutions | Satellite Radio | HD Radio | Bluetooth
Halston@BSW is offline   Reply With Quote
Old 02-13-2013, 01:16 AM   #7
cityjohn
My Ride: 2001 M3
Thank you for that! I've been looking in my trunk for 12V on-with-ignition, but if I can't find it there I'll look behind the dash
cityjohn is offline   Reply With Quote
Old 02-13-2013, 01:25 AM   #8
Halston@BSW
My Ride: E30 X5 TJ
No problem. Always test with a meter to make sure 100% but in most cases that will be true. I think almost every Valentine1/Escort radar is hard wired to the purple/white stripe at the sunroof panel
Halston Pitman
