Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
Hi all!
Im AA stage1 user and it is good So, im going to use 70mm pulley, who could tell me, how much PSI can Rotrex do? I think i will do engine rev limit at 7200-7500RPM. I will rebuild (tune) engines head, upgrade oil pump, engines cooling system and I have forget pistons 9,5compression I want run around 14PSI And one more question, what fuel pump i should use: 1. AEM 320 LPH Fuel Pump 2. Aeromotive 11142 340 LPH Thank to all! |
#2 |
My Ride: ZHP Custom Stage 3.5
C38-81 max impeller speed is 90k rpm.
Think you be passing that with a 70mm and will have tons of issues with belt slipping. (I have this issue with 85mm pulley,
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#3 |
You should change the belt.
My belt from AA have been alife for an around 4000km, than it was burned out because of slide. I have changed it for another one 5mm shorter and all comes to work right. There is some solutions to use wide belt. |
#4 | |
#5 | |
Viral Vahia
Active Autowerke | 9940 SW 168 Terrace Miami, Florida 33157 www.activeautowerke.com | viral@activeautowerke.com Phone: 305.233.9300 Ext. 232 | Fax: 305-253-8921 Last edited by Viral@ActiveAutowerke; 02-13-2013 at 05:02 PM. Reason: Auto-save 1360796546 |
