Old 02-07-2013, 02:14 PM   #21
My Ride: Lexus
Originally Posted by spherehunter View Post
I am going to replace cap, but belts are new. I will also be changing plastic bleeder screw for a metal one. Fan seems to be newer. Ill have to check. Thanks for the input.
I copied the cooling system kit directly from Bavarian Auto Sport they labeled it as an upgrade not I.
No. you labled the metal impeller as an upgrade
Old 02-07-2013, 02:31 PM   #22
spherehunter
My Ride: 2001 BMW 325i
spherehunter is offline   Reply With Quote
Old 02-07-2013, 02:32 PM   #23
Dave1027
My Ride: '06 IR zhp coupe
Probably the way to get most (if not all) of the plastic out of the head and block would be to remove the water pump, hook up a garden hose to T-stat housing where the upper radiator hose connects and turn it on full blast. That should back flush all the crap out.
Old 02-07-2013, 10:34 PM   #24
heechkass
My Ride: 323i Touring, 2000
Thanks, The belt is new I was definitely going to replace water pump plastic pully with a metal one. BV Auto have a cooling overhaul kit for 334.95. I have to check out which tensioner I need to get.
Complete cooling system overhaul in a convenient kit! Includes the following components:
Radiator - Nissens
Radiator Expansion Tank
Upper Radiator Hose
Lower Radiator Hose
Coolant Level Sending Unit
Expansion Tank Bleeder Screw
Water Pump & Gasket - With Upgraded Metal Impeller - Meyle
Thermostat & Gaskets - Wahler
Coolant Temperature Sensor
I cant find anything on the Transmission check valve though.
Thanks for your response.
Check the part number for transmission valve from realoem. You will most likely break it
heechkass is offline   Reply With Quote
Old 02-07-2013, 11:09 PM   #25
heechkass
It seats at the bottom of ET.
...and don't get Mango going on this topic. Just nod your head and say yes Sir!
Old 02-07-2013, 11:22 PM   #26
heechkass
Here's the part..
By the way you need to identify or automatic...
Old 02-08-2013, 08:27 AM   #27
spherehunter
Thanks for all your help.
