Old 02-03-2013, 11:31 AM   #1
DjDru
My Ride: 2002 330i
Eagle Eyes Help???
hey guys, i need your help badly, i've searched and searched and no answer to my specific problem. i just install my EE led tail light for my 2002 330i. everything was pretty simple, i even did the ground wire fix. here's my problem......
everything works, signal works, brake light works, no Dash warning......problem is my regular tail lights. when i turn on the head lights, my rear lights does not come on at all except for the trunk part, however....when i step on the brake, the rear tails does light up. can anyone please help me on this.
DjDru is offline   Reply With Quote
Old 02-03-2013, 12:21 PM   #2
05_325xi
My Ride: 2005 BMW 325xi
Check your fuse
05_325xi is offline   Reply With Quote
Old 02-03-2013, 12:44 PM   #3
DjDru
My Ride: 2002 330i
Originally Posted by 05_325xi View Post
Check your fuse
ok, will do. but if the rear parking light fuse is out, shouldnt the trunk piece be out also?
Old 02-03-2013, 12:47 PM   #4
05_325xi
Some cars do have 2 parking light fuses my Lexus IS300 did just check all your fuses good luck dude
Old 02-03-2013, 07:43 PM   #5
DjDru
My Ride: 2002 330i
ok, so...... when i step on the brake, the tail lights come on (brake lights) then when i step off the brakes (while headlights are on) the tail lights stay on (like they're supposed to, dimmer than brake light) but only for one second then it goes out again. someone please help me!!!!!
Old 02-03-2013, 07:48 PM   #6
j_block
My Ride: 2003 325i
Originally Posted by DjDru View Post
ok, so...... when i step on the brake, the tail lights come on (brake lights) then when i step off the brakes (while headlights are on) the tail lights stay on (like they're supposed it, dimmer than brake light) but only for one second then it goes out again. someone please help me!!!!!
Did you buy the lights brand new or used?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 02-03-2013, 07:53 PM   #7
Zell
Zell's Avatar
My Ride: so turbo wow
Did your old lights do this?
Old 02-04-2013, 09:42 AM   #8
DjDru
My Ride: 2002 330i
brand new from DDMtuning
i am 90% sure it didnt, but i will swap them back to make sure. i just bought the car and first thing i did b4 even registering was change the tail lights.
Old 02-04-2013, 11:55 AM   #9
Surrept
My Ride: 2002 330ci
If both sides are doing it I would say it's unlikely that it's the new tails...
Surrept is offline   Reply With Quote
Old 02-04-2013, 12:06 PM   #10
trj
My Ride: 325Ci
Swap in the old ones and check if its the wiring problem as suggested.
I know that the little black boxes connected immediately after the EE tails are the ones that control the turn signals, brake and tail lights.
You might have got defective boxes on both sides(unlikely but possible).
Try swapping the boxes to the other side, they are not side specific but may rule out any connection issues.
Else return them.
Old 02-04-2013, 12:10 PM   #11
DonaldE
My Ride: 2002 330i
It's a bad ground. That's all. They'll work until running lights are turned on.
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 02-04-2013, 01:30 PM   #12
DjDru
My Ride: 2002 330i
Makes sense... the ground im using is the lower nut/bolt from the tail light. I did not sand the paint off also. Ill report back my results later.
Old 02-04-2013, 09:27 PM   #13
DonaldE
My Ride: 2002 330i
Good luck. Lemme know
2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Locked/Loaded/Loud
DonaldE
Old 02-06-2013, 04:53 PM   #14
DjDru
My Ride: 2002 330i
2002 BMW 330i
No good. I grounded both lights to the chasis, even tried directly to the battery. Still the same problem.
Old 02-06-2013, 08:02 PM   #15
DjDru
My Ride: 2002 330i
guys, here's a video of what's going on. everything works.... except for the regular tail lights (when head lights are on). my tail lights do not stay on, then when you press the brakes and release, it comes on/stay on for 1 second and then fade off, but brake light works fine and the trunk light work fine. here's the video to help explain.
http://s916.photobucket.com/albums/a...206_162306.mp4
Old 02-06-2013, 09:44 PM   #16
DonaldE
My Ride: 2002 330i
Hmmm
Lemme think
Old 02-08-2013, 01:42 PM   #17
DjDru
My Ride: 2002 330i
you tube video of my lights in action....
