E46 Xi Forum
Old 02-03-2013, 12:38 PM   #1
nox9colt45
My Ride: '03 325XI
Chasing a shimmy....
As title says, I have a shimmy that I am at a complete loss on. It starts once i hit around 60-70mph. Some days are worse than others (it seems to vary in how bad it is) Things I have recently done to car:
Tie Rods (got alignment)
Tires (Obviously balanced when i purchased which was maybe 2000 miles ago)
Control Arms
Inner Ball Joints
Control Arm Bushings (Powerflex)
Sway Bar End Links
Front Axles (Reman)
As you can see i have done almost everything in front end. Shocks/Springs and Wheel bearing is about only thing left that could cause that. Maybe Steering rack but i sure hope not. I do have vibration when braking and my pads/rotors have about 50k miles on them so i do plan on changing those out soon, but that shouldn't cause vibration when not braking? Unless they are REALLY warped?
Further diagnosis I can tell is grabbing the wheel at 3-6 there is a little play (slightly more play in driver side compared to passenger) There is absolutely 0 play when i grab at 12-6. This, to me, rules out wheel bearing. This also somewhat rules out bent rim/bad balance. This could still be an issue (I do have a little road rash on my rims) but considering I have that play there must be something else wrong?
Anyone have any thoughts? Like i said, I am at a complete loss.
Also, all parts were replaced, unless noted, with Lemf parts. So i used high quality.
nox9colt45 is offline   Reply With Quote
Old 02-03-2013, 05:19 PM   #2
e46alfonso
My Ride: 330xi MT, mustang gt
What axle brand?
Old 02-03-2013, 05:27 PM   #3
nox9colt45
My Ride: '03 325XI
A1 Cardone
Old 02-03-2013, 05:51 PM   #4
e46alfonso
Ahh that might be the problem. Those axles leak fluid from the seals. The fluid level could be low. When i had cardones i was topping off the diff fluid every two weeks. I use OEM GNK axles now.
Old 02-03-2013, 06:07 PM   #5
nox9colt45
My Ride: '03 325XI
Good to know, I have heard mixed reviews on those axles but at the price i figured I would give them one shot. Ill keep an eye on the fluid level.
But that shouldnt effect the wheel having play when i grab at 3-6...
Old 02-03-2013, 07:20 PM   #6
Kubica
My Ride: 2003 325xi
So I find that the best way to find worn suspension components is with three people: one to hold the steering wheel as still as possible, one to shake the wheel, and one with a flashlight and pry bar under the car searching for the issue. Have both front wheels or rear wheels off the ground at the same time so you aren't preloading the sway bar.
That said, if I had to guess, it sounds like a lug nut may be over torqued.
Old 02-04-2013, 02:49 PM   #7
SamDoe1
My Ride: 4cyl of fury
Have you had your wheel balance checked?
Old 02-04-2013, 02:53 PM   #8
nox9colt45
My Ride: '03 325XI
I have had my wheels balanced twice, once with old wheels, and once with new when installed. I don't think either company used Road force however. From what I have read thats by far the most reliable machine.
I might rotate wheels and see if shimmy moves from steering wheel to the seat. Will at least help me narrow it down a little bit more.
