General Off-Topic
Old 02-03-2013, 06:50 PM   #1
ryanwhite74115
My Ride: 2011 Hyundai Sonata
Coax and speaker wire double gang wall plate?
Can someone point me to where I can buy a coax and speaker terminal wire double gang plate?
Preferable 3 speaker ports (6 total) on the left gang and 1 coax socket on the right gang?
I've been looking on amazon and google and haven't found anything so far?
Add these together on a double gang and I'm good:
http://www.amazon.com/GLS-Audio-Bind...nal+wall+plate
http://www.amazon.com/Petra-11-0415-...oax+wall+plate
(\ /) or \(`–' )/
c('')('')
ryanwhite74115 is online now   Reply With Quote
Old 02-03-2013, 07:32 PM   #2
MpoweredM
Wants to be Orange
MpoweredM's Avatar
My Ride: 1098S; RR Sport; CRZ
I'd custome wire it myself to be honest. Purchase open plates and purchase the individual fillers.
This is what I did in my theatre room.
Something like...
http://www.crutchfield.com/S-sSzkCkB...s-Inserts.html
Click for pics of my bikes
Click for pics of my old 335
Click for pics of my old S4 avant
Click for pics of my old M3
Originally Posted by v8 5 View Post
Constatine would of thrown his dildo at the kidnapper and proceed to cry in his closet after said kidnapper escaped.
MpoweredM is offline   Reply With Quote
Old 02-03-2013, 07:55 PM   #3
Chris3Duke
Yep, purchase the modular ones (like the On-Q or Levitron) to give you exactly what you want. This is what I do.
Chris3Duke is offline   Reply With Quote
Old 02-03-2013, 08:17 PM   #4
Andy2108
My Ride: E46M3E92M3'67Cobra
I used these
http://www.amazon.com/DataComm-45-00...e+pass+through
That's not speaker wire, but you get the idea.
Old 02-03-2013, 08:30 PM   #5
v8 5
My Ride: 6 speed BMW
I'm here for the double gang
Gutted with a Getrag
v8 5 is offline   Reply With Quote
Old 02-03-2013, 09:01 PM   #6
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Well played.
Malo periculosam libertatem quam quietum servitium
JonJon is offline   Reply With Quote
Old 02-03-2013, 09:40 PM   #7
ryanwhite74115
Something like...
Yea, that's what I just did. Quite a bit more expensive than the standard plates but that was really my only option.
(\ /) or \(`–' )/
c('')('')
Old 02-03-2013, 10:05 PM   #8
dauble2k5
My Ride: Facelift Coupe
Would MonoPrice have what you're looking for?
http://www.monoprice.com/products/se...ana+wall+plate
dauble2k5 is offline   Reply With Quote
Old 02-04-2013, 01:39 AM   #9
blownE30M3
My Ride: 2004 JB M3
Send a message via AIM to blownE30M3
You can get them all in one gang or double, whatever you want to do, they are all snap in connectors anyways... Just use Leviton's Quickport System.
Coax Insert
Speaker Terminal Inserts
Quickports
Home Automation and A/V Programming
http://www.xsdesignstudios.com
blownE30M3 is offline   Reply With Quote
Old 02-04-2013, 07:03 AM   #10
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Originally Posted by Andy2108 View Post
I used these
^ This is the answer. They make single gang versions as well.
They also make the flush versions. ($2-$4 for DataComm)
More connections = more resistance.
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI cables on a BMW board since 2005.
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD/JL (works for me)
1968 Ford Mustang with Polk/ADS (my first car and runs strong)
2007 Lexus GS350 with every option (I loved it)
2000 BMW DINAN M5 (will be missed)
2001 BMW 330ci (will be missed)
GlockMan is offline   Reply With Quote
Old 02-04-2013, 08:41 AM   #11
Chris3Duke
He already went the On-Q / Levitron route.
IMO, that route looks superior to the passthrough option (from a looks perspective). I'm not sure I buy the resistance is going to have a measurable impact. Certainly not on the coax...
Old 02-04-2013, 08:50 AM   #12
casino is no lie
My Ride: M54B30
http://www.mycablemart.com/store/car...t_detail&p=965
casino is no lie is offline   Reply With Quote
Old 02-04-2013, 09:02 AM   #13
GlockMan
GlockMan's Avatar
I used these
3db is 3 db.
To each their own.
PS - What happens when he needs extra cables? HDMI? Component?
Old 02-04-2013, 09:18 AM   #14
SamDoe1
My Ride: 2004 330xi, 3 pedals
3db is 3 db.
To each their own.
^ This.
I thought about going with the built in route but the thought of having to either get a new gang plate every time I get a new device would suck. Other option is to get many more ports than I need and that sucks too.
While the signal degradation on the digital side doesn't matter, the speaker signal will certainly degrade.
Old 02-04-2013, 11:12 AM   #15
Chris3Duke
Why? I've done two different things in my houses and my parents & in-law's:
- Gone with extra ports (ie. 4 when I only need 3) and used blanks in the extra hole. I usually do this when I know there's an extra, unused wire in the wall (maybe a second coax or something), but don't want to terminate it for whatever reason.
- Switched out the plates (upgraded from 2 to 3 or 4, 4 to 6, etc.). It's minimal work compared with running the cable through the wall. Dirt cheap too. The plates are cheap, and I'm never doing more than one or two at a time.
As for Glock's post, the whole point is that these systems are modular. Need HDMI? There's an insert for that. Need component? There's an insert for that too.
Either way, the hard part is running the cables in the wall. Terminating them is easy.
Edit: I'll also say, the downside to your way is the length of the cable. What happens if you need to move something and need a longer cable? You have to do an entirely new run. If you terminate, the in-wall stuff stays the same, and your patch cable is the only thing that gets switched out.
For the signal degradation, couldn't you run larger speaker wire in-wall to allow for this?
Old 02-04-2013, 11:25 AM   #16
SamDoe1
To each their own, I just prefer to not have multiple terminations in my cables from a simplicity standpoint.
My home theater is set up in a way that I won't be moving anything ever and if a longer cable is needed, they make extension adaptors.
Larger speaker wire is more expensive so you add unneeded cost to your application.
I do see the advantages to your way and I'm certainly not knocking it, just not the way I'd do it.
Old 02-04-2013, 12:44 PM   #17
GlockMan
GlockMan's Avatar
HDMI has enough issues in its own before you start "terminating" them into wall plates.
Show me the termination plate that properly handles a simple home theater receiver:
(3) HDMI
(2) Component (6 RCAs)
(2) Digital Coax
(3) Cat5
(7) Speakers
(1) Subwoofer Coax
(2) Coax
(1) Basebank AV Set (3 RCAs)
That is 27 connections - You would have to use 5 Gangs of 6 port plates vs one 2 gang shoot port with better signal quality.
Have you ever considered the fact that you are intercepting high end cables with cheapo connectors? Weakest link is the wall plate itself.
But hey, they make em for a reason.
Old 02-05-2013, 03:11 PM   #18
blownE30M3
My Ride: 2004 JB M3
It's negligible, in 99% of installs you wouldn't notice a difference at all.
I find it hilarious that there are proposals of monoprice parts and the topic of speaker level degradation in the same topic.
