Sponsored by BimmerWorld
Old 02-10-2013, 09:52 PM   #1
andrewrp
My Ride: 1999 E46 328i 4D MT
Awkward Car Stance
So I just put on some 18" VMR CSL's on my E46 328i Sedan on 235/40/18 front and 255/35/18 tires and I'm kinda disapointed on how it looks, looks awkward, I have coilovers to drop the car that I havn't installed yet, will it look better once dropped?
andrewrp is offline   Reply With Quote
Old 02-10-2013, 09:55 PM   #2
ANREC330
My Ride: C6 Vette & M3
Yes drop it first to see the difference. Your offset plays a big role also.
ANREC330 is offline   Reply With Quote
Old 02-10-2013, 11:31 PM   #3
andrewrp
et45 front et40 rear
Old 02-10-2013, 11:44 PM   #4
NFSx328ci
My Ride: TiAg E46
ID:	490204this is what it might look like if lowered so do it. They looked great for me before the drop aswell. Post a pic of yours to see
My babies; Supercharged 328ci, 2009 Alpine White 135i.
625awhp 99 GSX(SOLD), Straight Piped 2011 Grand Cherokee (SOLD)
NFSx328ci is offline   Reply With Quote
Old 02-11-2013, 12:17 AM   #5
andrewrp
Here it is
Old 02-11-2013, 01:32 AM   #6
ANREC330
Definitely lower it. Mine looks like it has a lift kit too lol
Old 02-11-2013, 01:33 AM   #7
ANREC330
Here's mine.
Old 02-11-2013, 01:43 AM   #8
BWOODM3
My Ride: 2002 M3 convertible
Post pics after you install the coilovers aswell
BWOODM3 is offline   Reply With Quote
Old 02-11-2013, 01:53 AM   #9
andrewrp
Here's mine.
Attachment 490218
Hahaha atleast I'm not alone, are you on 18"s?
Old 02-11-2013, 02:16 AM   #10
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
OP, please post pics that arent grainy...
lower it (as mentioned) and get it aligned - it needs more neg camber in the rear it seems from the grainy a55 pic
/_________\
O==[][]==O
Old 02-11-2013, 02:30 AM   #11
ANREC330
Yes sir. 18x9.5 front and 18x10 rear on stock suspension. Coilovers are definitely going on soon then ill slam it
Old 02-11-2013, 02:07 PM   #12
andrewrp
just wondering, does the tire size choice I made add to the awkward stance? Should I have gone higher side walls in the back and lower in the front? I just went with the size tires that a reputable modding store gave me
Old 02-11-2013, 02:40 PM   #13
andrewrp
I just noticed that the Driver's side is higher than the passenger side as well
Old 02-11-2013, 03:01 PM   #14
NFSx328ci
My Ride: TiAg E46
Do you mean your ride height is lower on one side more than the other? Or your sidewall?
Old 02-11-2013, 03:29 PM   #15
andrewrp
ride height, the driver's side fender is a tad bit higher from the tire than the passenger's side
Old 02-11-2013, 03:34 PM   #16
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Cars look goofy with big wheels and OEM suspension
Timeless Motor Group
Old 02-11-2013, 03:39 PM   #17
NFSx328ci
My Ride: TiAg E46
It could just be an old and worn out spring pad. Those are cheap to replace. That can make your car look lower on a side by just a tad bit if one is good and the other is super worn
Old 02-11-2013, 03:48 PM   #18
andrewrp
will that be irrelevant once I install the coilovers?
Old 02-11-2013, 03:59 PM   #19
NFSx328ci
My Ride: TiAg E46
You are still going to be using a spring pad, just depends where your height adjuster is for your coilovers. Some are at the bottom and others are on top
Old 02-11-2013, 04:00 PM   #20
NFSx328ci
My Ride: TiAg E46
But not as goofy as lowered and modded out with smaller wheels and snow tires on . Lol. never again
