///M3 Forum
Old 02-04-2013, 09:13 AM   #1
choxor
My Ride: JDM
VANOS Solenoid Pack Failure
There are threads on this, but I wanted to share my experience just in case someone has a similar problem or throws similar codes. Archived for searchable goodness.
Car was running fine, no codes and no intermittent issues. 80K on the clock, all maintenance records and inspection II completed within the last few months. Driving home from work the SES light came on. When I'd come to a stop the idle would dip to ~500 and the car would shake. The idle RPM would return to normal after the dip, but the car still shook quite a bit. When driving the car would feel fine, though.
When I got to the house I fired up INPA. IF YOU DO NOT HAVE SCANNING SOFTWARE/CODE READER BUY ONE NOW. NO EXCUSE NOT TO HAVE ONE IF YOU CAN AFFORD AN M3.
Heart sunk when I saw the codes:
184 - EVanos1 Regulation
67 - EVanos1 Early Valve
72 - EVanos1 Late Valve
Misfire codes for all 6 cylinders
For those who do not know, there are two failures that can cause this to happen. Either the VANOS solenoid pack has failed or the exhaust sprocket hub tabs have sheared off. The latter being way more expensive than the former.
There is only one "test" you can do. Clear the codes, turn the car on, and let it idle. Usually, if it's the solenoid pack, the problem is intermittent and the codes will not come back for a while and the car will seem fine. If the exhaust tabs are sheared the code should come back within three minutes or so.
This is NOT a perfect test. It assumes the solenoid pack will only fail intermittently, which may not be the case. The only way to really tell is to remove the valve cover and inspect the tabs. If they're still present then it should be solenoid pack.
In my case the codes did not come back after 5 minutes of idling or a short spin around the block, however the car was still idling bad and RPM's were still dipping when coming to a stop. If I had let it idle longer I'm positive the SES light would have come on, but it would be pointless because the VANOS was still obviously not working.
I took the gamble and ordered a new solenoid from Beisan. He repairs units and improves the design to stop the solder joints from screwing up, which is what causes the failure (and why the failure is usually intermittent). Plus it's only $150 after a $150 core return, which is WAY better than $600 for a new unit. Find it here: http://www.beisansystems.com/products.html
I also ordered the S54 Vanos Sealing Plate Repair Kit per the instructions.
Ordered on a Thursday and had it in my hands by Friday. $25 for overnight shipping to my area. Rajae, I owe you a beer. Install took about an hour and 90% of that was cleaning, which I took my time with. As usual Beisan's instructions are flawless. Find them here: http://www.beisansystems.com/procedu..._procedure.htm
One thing to note, the seals on my sealing plate were done. Really. Really. Really plasticized and flat. Checked the oil, crossed my fingers, and fired her up. Flawless victory.
As a bonus I seem to have picked up some throttle response. Car's quicker to react, which I've read in other threads. So cleaning the valve body, oil pressure restrictor, replacing/cleaning the filter, and replacing the plate seals may good PM to do during an inspection I, II, or VCG change. It's cheap, doesn't take much time, and you may feel the results.
Sadly there is no PM for the solenoid pack itself. It's basically a design flaw and I'm certain that every M3 will eventually be effected. Thanks to Rajae at Beisan for providing a fix that doesn't obliterate the wallet.
choxor is online now   Reply With Quote
Old 02-04-2013, 12:56 PM   #2
taylor192
My Ride: 2003.5 M3
The reason the car feels better is cause the Vanos is working. When the car detects the Vanos is malfunctioning it locks the timing. Since the failures usually happen under load the timing is locked at high rpms, thus low rpm performance suffers (thus the crappy idle you observed).
Glad it worked out for you. I had a similar issue and the Besian solenoid solved it. I could almost reproduce it consistently at high RPMs, which I guess stresses the solder joints just enough to fail.
Old 02-04-2013, 04:14 PM   #3
-ForceFed-
My Ride: S40 T5 / E46 M3
How many miles does your car have?
TheRetrofitSource | 2020 Motorsports | RTernie | H&R Springs | Import Meet | Girodisc
-ForceFed- is offline   Reply With Quote
Old 02-06-2013, 04:32 AM   #4
46smg
My Ride: 2003 M3
I had the same Vanos problem about a year ago. But instead of buying a new solenoid coil pack, my mechanic opened up the solenoid coil pack housing and found 3 broken connector pin solder joints. He re-soldered the pins and resealed the plastic housing. At the same he replaced the Valve Cover Gasket Set and the Vanos Gasket. I haven't had any problems since.
46smg is offline   Reply With Quote
Old 02-06-2013, 08:41 AM   #5
choxor
My Ride: JDM
I thought about re soldering it, but I didn't want to chance it happening again. Beisan adds a couple of tweaks to make it more durable, but if you're handy with a soldering iron that's definitely an option.
Old 05-06-2013, 02:56 AM   #6
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
Good info here. I got this code with the same symptoms you described
1b16 - exhaust camshaft vanos advance valve
Does it sound like the solenoid? I had the same idle drop issue for approx 2 months. I did a valve adjustment approx 7500 miles ago and the tabs looked be to be in great shape.
itscoo2pyopants is offline   Reply With Quote
Old 09-30-2014, 04:30 PM   #7
J.P.R.F.
My Ride: E46 M3 SMG 2002
Guys,
Can it be that failed Vanos system blocks SMG gear shiftings or stop hydraulic pump?
My M3 has really strange behavior (described on the last page here: http://forum.e46fanatics.com/showthr...6054&page=13):
After some time of working idling or driving (doesn't matter), the engine starts sounds a little bit loud, vibrating (knocks), rpm floats, and I fail to shift gears (e.g. from neutral to 1st) so can't move on - no errors in SMG ECU (however I see via Inpa that activation conditions of hydraulic pump not fulfilled and hydraulic pressure is -12bar) but got following INPA errors in DME:
=> 184 EVANOS1 Regulation (actual value too low)
=> 17 SMG switching process (0100-Broken wire / Value missing).
My bmw service assumed is that it is a problem with Vanos Solenoid Pack.
We consider that DME has this info that something is wrong and send it to SMG ECU and it send some signal to stop the pump/shifting and acceleration.
Do you thing that this can be and diagnosis is correct?
J.P.R.F. is offline   Reply With Quote
Old 09-30-2014, 06:46 PM   #8
Teslazerok
My Ride: 2003 M3 6SPD
Never heard of a vanos fault stopping the smg from engaging, but I can't say it's impossible.
In any case you should check if your exhaust hub is intact, if it is replace the solenoid with a beisan one.
I would assume your smg issues are a separate problem from the vanos.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 10-02-2014, 06:29 AM   #9
J.P.R.F.
Question
I've ordered S54 Vanos Solenoid Pack from Beisan, expect in 1-2 weeks, will keep you posted on the results.
Yes, I'm also doubting that Vanos can has a direct impact on Smg system and stop pump or gears change...
Dear Experts,
Please, share your experience on this topic!
Old 10-02-2014, 04:19 PM   #10
andrew m.
My Ride: Oxford Green E46 M3
Based upon this post (and numerous others), I just ordered the full repair kit from Beisan.
Anyone have a rough guess on what the labor time / cost would be on this job?
Cheers,
Andrew
Oxford Green / Slick Top / 6 spd / Cloth
andrew m. is offline   Reply With Quote
Old 10-02-2014, 06:10 PM   #11
SKR7
My Ride: E46 MY04.5 SMG M3
Cheers,
Andrew
Me too. One kit for me and one for a friend.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
