Panic-Help-Parked in a Sandbox-Brake Issue-DSC - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 02-04-2013, 09:51 AM   #1
Brian's 325xi
My Ride: 2003 325 xi
Well not quite-But close in relative terms.
There are several cups of fine sand like brake dust in my garage under each of my left wheels.
Why/How is it shedding it the garage. Wouldn't it blow away before accumulation?
It makes a groan out the hub sometimes after the car is shut off. Brake system noise? ABS sensor
My rotors ground down significantly (have 1/4" rim) over the course of two weeks.
I did the front drivers cv axle 3 weeks ago and after have a thud, thud, thud that I thought was the wheel bearing. As its temp dependent and brakes ironically had no influence on thud and seemed functionally fine. Diff is fine. Shop says CV Axle is great and car fine-they're wrong obviously.
Would the DSC algorithm apply constant brakes to the left wheel?
I'm lost guys and I'm freaking out!
Brian's 325xi is offline   Reply With Quote
Old 02-04-2013, 09:55 AM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
I would first take a guess at sticking calipers. It is not uncommon to have a sticky caliper on cars of this age. I'd start there first. $100 total fix if you get your own remanufactured calipers.
It would be really, really rare if DSC messed up without telling you some sort of warning sign . You'd see the light flashing if it ever applied brake pulses, and then usually if it starts erroneously activating you'll see the light stay on. That is indicative of a wheel speed sensor.
Old 02-04-2013, 05:54 PM   #3
Brian's 325xi
Thanks man. I don't understand the so much (1" high piles) of dust in the garage though.
Old 02-05-2013, 10:26 PM   #4
Brian's 325xi
