Australia
Old 02-04-2013, 08:04 PM   #1
Degrees
My Ride: BMW 320i
Clutch Fan removal tool
Hey fanatics, I recently tried changing the VANOS seals on my 320i (auto) alongside a friend with a 323i (manual) and had an unpleasant surprise. It seems my auto car has it's fan mechanically linked to the engine and I need a special tool to remove it for access.
My question is, are there any fanatics in the Brisbane area who have such tool who would be willing to lend it out?
Sent from my GT-I9100 using Bimmer App
Degrees is offline   Reply With Quote
Old 02-04-2013, 08:09 PM   #2
CortinaD
My Ride: lots
I just use a 32mm long spanner and smack it with a hammer and that always has been enough to crack the thread. It is a reverse thread so it isn't locked on tight when its installed.
CortinaD is offline   Reply With Quote
Old 02-04-2013, 08:19 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Yes, I too use a 32 mm opened end wrench. I use a screw driver between the bolts to hold the pulley steady. First time removal is the hardest.
BMWCaptain is offline   Reply With Quote
Old 02-04-2013, 09:06 PM   #4
Degrees
My Ride: BMW 320i
I too tried the hammer and 32mm technique. Unfortunately there wasn't enough resistance and the spanner just turned all the pulleys. I will try this screwdriver method.
Old 02-04-2013, 11:31 PM   #5
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
PM Ballistic325 for fan clutch tool.. it says so in his signature.
E46 Coupe is offline   Reply With Quote
Old 02-04-2013, 11:39 PM   #6
AmazingNutz
Banned User
My Ride: carpet
OP, I highly suggest you invest in one because its not expensive. You're gonna need to use it again in the future.
Sent from my G6
AmazingNutz is offline   Reply With Quote
Old 02-05-2013, 03:38 AM   #7
Ballistic325
My Ride: slow and steady
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
