Old 02-04-2013, 11:15 PM   #1
trentcdrums
My Ride: BMW 323i Sedan
Fog light HID wont ignite..
So I ordered 9006 6k bulbs and Purchased super slim ballasts for my headlights, and used my old xentec ballasts for my fog light ballasts. Connected everything successful and nothing! So I switched to the other ballasts, and NOTHING! What am I doing wrong?
Old 02-05-2013, 12:33 AM   #2
trentcdrums
Anyone?
Old 02-05-2013, 12:53 AM   #3
DonaldE
My Ride: 2002 330i
I have a strong feeling that your car knows how awful it will look with hideous 6k "HIDs". That being said, it's probably a ground issue. Check them
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 02-05-2013, 01:09 AM   #4
tuscan1205
My Ride: e46 325CI, w212 E550
water? corroded connection? cheap ballasts? cheap bulbs? water?
'02 Orient Blue 325Ci
tuscan1205 is offline   Reply With Quote
Old 02-05-2013, 09:36 AM   #5
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
9006 an HID bulb? Thought that was a halogen bulb.
HacksawMark is offline   Reply With Quote
Old 02-05-2013, 10:13 AM   #6
trentcdrums
They made the hid bulbs fit the socket so it's fits fine.
Old 02-05-2013, 10:14 AM   #7
trentcdrums
Zero water. They light the regular bulbs, and the ballasts light my headlights. And I switched connections and nothing still happened.
Old 02-05-2013, 10:15 AM   #8
vandyboy
My Ride: 2001 325i
Did you check the fuses and relay?
vandyboy is offline   Reply With Quote
Old 02-05-2013, 10:21 AM   #9
trentcdrums
Not yet. But the other fog light that is still stock turns on..
Old 02-05-2013, 10:22 AM   #10
trentcdrums
And when I hook the stock stock bulb up its works.
Old 02-05-2013, 10:24 AM   #11
FastHackem
My Ride: E60 M5
Get a HID relay harness. Not enough juice to power your ballasts.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 02-05-2013, 10:33 AM   #12
vandyboy
My Ride: 2001 325i
That was what I was thinking too, FastHackem. Too much power required for the wiring to handle for HIDs. I figured it shot the relay or fuse.
Old 02-05-2013, 04:10 PM   #13
trentcdrums
Would any local stores have them instead of ordering?
Old 02-05-2013, 04:32 PM   #14
FastHackem
My Ride: E60 M5
Try a local custom audio shop. Often times they sell and install HID systems. I would call first though.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 02-05-2013, 05:57 PM   #15
trentcdrums
I have called all over the place and no luck.:/
Old 02-05-2013, 05:58 PM   #16
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Do you get any flicker on the gauge cluster when pressing the fog lights switch?
Old 02-05-2013, 06:08 PM   #17
trentcdrums
Nothing at all. The light wouldn't light or anything. But the other stock fog was on. So the fuses are good.
Old 02-05-2013, 06:23 PM   #18
DOT.
My Ride: '04 ZHP Sedan
Try reversing your OEM plug the goes into the ballast.
DOT. is offline   Reply With Quote
Old 02-05-2013, 09:25 PM   #19
trentcdrums
I am really glad that you said this, because they worked right when I tried this idea. Thank you a bunch!
Old 02-06-2013, 12:24 AM   #20
DOT.
