Old 02-11-2013, 12:10 AM   #21
TrippinBimmer
My Ride: Just Fast!
Does it goes away after awhile? Probably need a new belt. Had the same issue. Metallics sounds...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 02-11-2013, 07:03 AM   #22
str8dum1
My Ride: VQ38DETT
Thats good to hear! Pretty much like I expected based on when you described the noise.
Originally Posted by danglerose View Post
Errr..had the car checked out and the "pinging"
was not pinging but something else in the pulleys that sounds like marbles. It does not effect performance one iota. It is a purely mechanical noise, not a detonation of any sort. Unfortunately the shop close to me won't touch anything to do with the SC system. I will have to go to the shop that did the install to get it sorted. Good to know that my engine is in no danger of blowing up. PHEW
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline   Reply With Quote
Old 02-12-2013, 09:28 AM   #23
Andrew@Activeautowerke
Past Site Sponsor
My Ride: 135 Fbo+meth & E85
Thanks for the update.
Andrew@Activeautowerke is offline   Reply With Quote
Old 02-12-2013, 12:12 PM   #24
jonny_blaze
My Ride: E46 M3 AA HKS S/C
Errr..had the car checked out and the "pinging" was not pinging but something else in the pulleys that sounds like marbles. It does not effect performance one iota. It is a purely mechanical noise, not a detonation of any sort. Unfortunately the shop close to me won't touch anything to do with the SC system. I will have to go to the shop that did the install to get it sorted. Good to know that my engine is in no danger of blowing up. PHEW
Should have consulted junior2552 a long time ago, from what I see here...
jonny_blaze is offline   Reply With Quote
Old 02-12-2013, 07:04 PM   #25
danglerose
My Ride: 2004 330 cic
Send a message via MSN to danglerose
Problem solved. AS the noise increased to a whine/squeal above 1200 RPM I had alisten under the hood and determined that it was coming from the pulley of the charger itself. I adjusted a very loose tensioner on the rear bracket to cant it forwards and voila! No more whine. Note to self- get a long handled 13mm wrench. Thank you all for your attention. You may now get back to your regularly scheduled legitimate problems.
2004 330 Cic
AAW Stage 2 VS3 Supercharger
AEM AFR gauge AEM 0-15 PSI boost
Aftermarket M3 power/fold mirrors with signals
Pioneer AVIC N4 DVD/NAV, bluetooth, XM, HD
DIY VDO Gauge cluster, autodim homelink rearview, LeatherZ illuminated Shift, BMW OEM Alarm Retrofit, Hard Top anchors, Alcantra shift and brake boots, Alcantra M3 steering wheel, BMW OEM Aluminum Pedal upgrade, BMW OEM Hardtop mount with Anthracite Hardtop, M3 spoiler
danglerose is offline   Reply With Quote
Old 02-13-2013, 08:39 AM   #26
Past Site Sponsor
Old 02-13-2013, 04:42 PM   #27
TrippinBimmer
My Ride: Just Fast!
OP glad you got it fixed. If the belt have some slack I would go -2mm shorter belt. Will help a lot.
Lolz
Alpine White M3
MaximumPSI Stage4
Old 02-14-2013, 04:18 PM   #28
Junior2552
My Ride: 2005 ZHP
Very funny gentlemen. Just because my post didn't turn out to be relevant here doesn't make it false.
Junior2552 is offline   Reply With Quote
