Old 02-05-2013, 02:54 AM   #1
andrewlu
My Ride: E46 325i
Smile DIY:How to remove the rear backrest
Hello guys,
Somebody help to give me some instruction that how to remove the rear backrest of E46?
PS, I know how to remove the cushion, but for the backrest, I have no idea.
Thanks.
andrewlu is offline   Reply With Quote
Old 02-11-2013, 12:31 AM   #2
the_stick
My Ride: 330i
Whatever you don't twist the stems with pliers like some posters suggest. Yes, that idea will work, but you'd put scratches on the chrome plated stems and twist the plastic sleeve out of position.
Here's a safe way.
1. Raise the headrest all the way up. As you may already know you can't completely remove it even with tremendous force. There's a retainer clip holding each stem.
2. Grasp one stem at a time pull up while wiggling back and forth until the retainer clip gives way. You can't remove headrest yet because there's not enough room for stem.
3. Grasp other stem and do the same thing. Pull up while wiggling.
4. Once both sides are free from the rear deck, they should slide up from the plastic sleeves with ease.
the_stick is offline   Reply With Quote
Old 02-11-2013, 12:33 AM   #3
the_stick
My Ride: 330i
Sorry.
I misread.
Grasp top of backrest and pull towards you if it's a sedan (saloon). Then lift up.
