Old 02-05-2013, 03:36 AM   #1
My Ride: Lexus
Video: how to bleed your E46 non-m cooling system
I'll add this to the cooling thread (if it lets me. if not, i'll have to ask jake to add it) but I'll also put this in a new thread to increase the chance someone finds it. Hopefully it can give a visual aid in what to do. I put this together at midnight so sorry for any typos or inconsistencies.
Summary:
Step 1) Raise front of vehicle on ramps or incline. This helps the air bubbles escape easier.
Step 2) Insert key, turn to the ON position (dash lights on--engine OFF)
Step 3) Turn heater to MAX heat and fan speed to LOW.
Step 4) Completely remove bleed screw and expansion tank cap. Set aside.
Step 5) Pour your desired mixture of Genuine BMW coolant and distilled water into the expansion tank. Approximately two gallons will be used to satisfy an empty system.
Step 6) Once the system is starting to fill to capacity, water and air bubbles will escape the bleed hole. Have a bucket to catch the spilling coolant. Keep pouring water or coolant (in my case, I pour distilled water only) until water comes out of the bleed hole without any bubbles. It should be a steady stream of water. Do this for about 2-3 minutes or until you are satisfied there are no more bubbles.
Step 7) Siphon off any excess water before reinstalling the bleed screw and expansion tank cap and eventually starting the engine.
Step 8) Monitor engine temps using the OBC method (Google it if you don't know how). Temps should read between 87 and 98c once the car has warmed up and driven. You might need to bleed again or top off coolant the next day.
Step 9) Keep monitoring for the next few days so the system stablizes.
Step 10) Visit E46Fanatics.com and check into my cooling thread if you liked this video or information. Let me know!
http://forum.e46fanatics.com/showthread.php?t=914109
Old 02-08-2013, 04:54 AM   #2
Vandyinc
My Ride: 2000 323 Cic
Thanks Mango, Good Video. Was it a coincidence or do you color coordinate your funnels with the fluids you pour through them?
Done:H&R Sport Springs Koni STR Shocks & Struts, Lower Control arms, FCABs, OFHG, CCV, Cooling Sytem refresh, Coolantsnitch. Yet to do:Transmission fluid & filter, VCG
Vandyinc is offline   Reply With Quote
Old 02-08-2013, 06:03 AM   #3
Goondaddy
My Ride: 2002 325ci
First off, thanks for doing this. You'll be surprised how much it helps visually inclined people.
On a side note: It's hard to read text when it's on a picture or video.
Goondaddy is offline   Reply With Quote
Old 02-08-2013, 11:12 AM   #4
My Ride: Lexus
coincidence but good idea
I agree... that's why there's my guide so you have both I also put the instructions in the youtube comments.
Old 02-08-2013, 11:14 AM   #5
matchee
My Ride: 2000 328i
Thanks I used your message in the other thread...
matchee is offline   Reply With Quote
