E46 Convertible
Old 02-05-2013, 08:37 AM   #1
mag48
My Ride: 330ic
Emergency Mode Manual Operator
There is a problem with my top. I was able to close it. I wanted to open it manually . . . I released the lid with the button. . . and released the top from the windshield. . .but it will not freely move freely. Help is appreciated
mag48 is offline   Reply With Quote
Old 02-05-2013, 09:46 AM   #2
tcphoto
My Ride: E92 335 MT Coupe
I had an issue with my top last summer and I thought the manual said not to take the top down manually.
tcphoto is offline   Reply With Quote
Old 02-05-2013, 11:47 AM   #3
taylor192
My Ride: 2003.5 M3
We need to sticky a thread on manually opening and closing the top. There are actually 2 sets of latches the front allen key controls. There's the latches at the windshield, and latches at the first hinge of the top. If the first hinge will not fold then you have to keep turning the allen key. If you watch the first hinge while turning the allen key you'll see a latch move.
The manual advises against it cause I think its not easy to get the storage cover to lock manually. I could not get the storage cover to lock when opening the top manually.
Old 02-06-2013, 07:26 AM   #4
mag48
My Ride: 330ic
Thanks for your reply. . .Have you or any one been able to raise and lower the roof manually?? . I noticed I had to turn the allen key in the windshield alot to close the roof. . . what you said makes sense. Have you tried to close the cover using the allen key on the closing motor inbetween the rear seats?
Old 02-06-2013, 10:53 AM   #5
taylor192
My Ride: 2003.5 M3
See my reply above. I was unable to get the storage cover to lock with the top down.
Old 02-07-2013, 07:04 AM   #6
mag48
My Ride: 330ic
I am just trying to troubleshoot here. . . I just want to put the top down to see if there is anything oviously wrong. .. . and then put it back up. Have any of you been able to do this manually ??? And if so what is the sequence.
Old 02-07-2013, 11:33 AM   #7
taylor192
My Ride: 2003.5 M3
You can put the top down manually, you just cannot lock the storage cover to leave it down and drive away.
Old 02-07-2013, 02:56 PM   #8
mag48
My Ride: 330ic
I have tried to lower it manually but it too ridged . . . can't move it .. . . I released it from the windshield what are the next steps. . . your help is appreciated.
Old 02-07-2013, 03:53 PM   #9
taylor192
My Ride: 2003.5 M3
I posted the trick previously, see above. If that's not clear take it to a shop before you damage the top.
Old 02-08-2013, 06:34 AM   #10
mag48
My Ride: 330ic
So once the "first hinge" is released the top should be foldable.
Thanks Taylor . . . your comments are both helpfull and appreciated.
Old 07-05-2015, 05:12 PM   #11
klixtokw
My Ride: bmw 325 ci
Taylor can you walk me trough the procedure to close the top in an emergency (rain storm) and the top decides not to close automatically?
klixtokw is offline   Reply With Quote
