E46 Xi Forum
Old 02-05-2013, 05:05 PM   #1
SeattleLSB
My Ride: 2003 330XI, 2003 M3
XI Oil Guide Tube
Does anyone know which part # is correct for the updated design? I figure while I replacing everything I should just install the new part.
Real OEM Does not show it.
http://www.realoem.com/bmw/showparts...87&hg=11&fg=10
11437531260 - $52.00
And I've seen 11437565438 and it's over $100
Any insight would help!
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 02-05-2013, 06:38 PM   #2
Kubica
My Ride: 2003 325xi
It looks like the part number you listed is correct. If your xi was made before 3/03, you will also need the "cable holder" referenced.
If your car was made 3/03 or after, you have the updated part per realoem. Check to see if that part number was ever used on a RWD e46 and see if it has been superseded.
Either way, I would just clean it and not replace it.
Old 02-05-2013, 06:43 PM   #3
SeattleLSB
My Build date is 03/03 which makes it even more complicated! I put the 03/03 build date and it gave me the 52.00 one. So do I need 11437565438?
Old 02-06-2013, 02:19 AM   #4
White_Knuckles
My Ride: 2003 325xi
I think the new flavor has a larger diameter outer tube less willing to clog.
I know my CCV is taking on strange behavior in the freeze. I read the "winter" kit has insulated tubing over all the fiddly pipes. Owners claim this sleeving is a pain to work with where some tear it off.
I am waiting 'till good weather to replace the bugger,clean the ICV etc. I keep looking at the catch-can option but probably will replace the factory bits and will upgrade that stick tube. I want the fix to work!
Old 02-06-2013, 05:23 PM   #5
GCoop
My Ride: '04 325xi
FWIW 11/03 build date here and I had the old design.
Also, I will second the notion of reusing the old tube after a thourough cleaning. Mine wasnt clogged at all but had some build up. After a good soaking ithe build up had dissolved and I expect it should be trouble free until the next CCV failure.
GCoop is offline   Reply With Quote
Old 02-11-2013, 02:00 PM   #6
SeattleLSB
GCoop What did you soak it in? I decided to wait and pull the stick to get a look at it first.
Old 02-11-2013, 03:05 PM   #7
GCoop
My Ride: '04 325xi
Gasoline, Brake cleaner, carb cleaner. I used it all.
Biggest tip is to get a small stiff piece of wire (or a pipe cleaner if you have it) and agitate the space in between the walls. I have even seen folks attach the wire to a drill and work it around to clean it.
The key is to do whatever it takes and use whatever to clean it.
Old 02-12-2013, 07:59 AM   #8
SeattleLSB
Seems like alot of work to clean a tube. I might just order the other tube now!
Joe
Old 02-12-2013, 08:36 AM   #9
bmwbob89
My Ride: M-5 325 X3 528 740
You need to the 438 tube and o ring. All M54 engines should use this. For some reason Real OEM does not list it. Its not cheap but worth avoiding the problems.
This Service Information bulletin supersedes SI B11 08 03 dated February 2009.
SUBJECT
Oil Separator - Cold Climate Conditions
MODEL
E39 (5 Series) all with M54 engine
E46 (3 Series) all with M54 engine
E53 (X5) all with M54 engine
E60 (5 Series) all with M54 engine
E83 (X3) all with M54 engine
E85 (Z4) all with M54 engine
E46 (3 Series) all-wheel drive only
Part Number Description Quantity
11 61 7 534 237 Oil Separator Repair kit 1
11 43 7 565 438 Dip Stick Guide Tube 1
11 15 7 532 629 Hose 1
bmwbob89 is offline   Reply With Quote
Old 02-12-2013, 11:59 AM   #10
GCoop
My Ride: '04 325xi
Joe
The new tube wasnt worth the ~$150 price to play for me and honestly it really wanst all that hard to clean the old one.
If the origianl wasnt fully clogged after almost 9 years then the new design wasnt really all that necissary for me.
Old 02-12-2013, 08:15 PM   #11
White_Knuckles
My Ride: 2003 325xi
^^ Sounds like that thing was pretty restricted? I thought the small gap was a winter clog-O-matic with water vapor, emulsification. (white/yellow goo). Cleaning would be futile if the passage is too thin.
How cold is it in VA?
Old 02-12-2013, 08:17 PM   #12
SeattleLSB
The tube is only 109 now these days. Got the rest of the cold weather CCV today. Looks like I might use some electrical tape around the CCV Valve to hold that insulation on etc.
Joe
Old 02-12-2013, 08:38 PM   #13
GCoop
My Ride: '04 325xi
Nah not really. There was some build up but I wouldnt call it extreme. I rarely make any short trips.
Where I am we can get some extreme cold stretches but it rarely falls below 0F.
