Winter wheels - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 02-05-2013, 09:19 PM   #1
acerboca
My Ride: 2001 BMW 330i
Winter wheels
I am currently in talks to buy a set of winter wheels for my 01 330i, the guy is selling beyern 5 spoke wheels 17x8 but staggered width for a 06 m3, will these work for my 2254517 blizzaks. Thank you in advance for your time
2001 Tiag Silver 330i sport package - vmr 18s staggered
acerboca is offline   Reply With Quote
Old 02-06-2013, 07:13 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Probably not, but if you post the actual width and offset of the wheels, we can let you know.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 02-06-2013, 07:59 AM   #3
acerboca
Gary, thank you for the reply, that is the problem though he does not know the offsets other than they are for an 06 m3
Old 02-06-2013, 08:12 AM   #4
Rudy@Tirerack
Moderator
The size and offset is stamped on the back of the wheels. If he really wants to sell them, he'll get them for you. Most buyers will want to know this information.
Old 02-06-2013, 10:37 AM   #5
acerboca
Gary thank you for the clarification just found out the offset front is 15mm and the rear is 40mm. The wheel are 17x8. I'm not opposed to using spacers just want to make sure they will clear and not rub horribly
Old 02-06-2013, 11:09 AM   #6
Rudy@Tirerack
Moderator
He must mean 15mm rear as the M3 has a lower rear offset. The 40mm offset wheels should work with no problem. I would be a bit concerned with rubbing on the 15mm offset version, but if you're able to keep those in the rear there is a chance it would fit without rubbing with 225/45R17. Spacers would push them out further and make rubbing worse.
Old 02-06-2013, 11:26 AM   #7
acerboca
For the price I think I may give them a try, thank you for your time and insight, also thanks for the great service always with tire rack
Old 02-06-2013, 11:46 AM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Agreed.
Be weary of that rear offset.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-06-2013, 11:53 AM   #9
acerboca
Will the rears with 15mm back spacing defiantly run if I am lowered on h and r sport springs? Thanks again for all of the help
Old 02-06-2013, 12:32 PM   #10
VMRWheels
VMRWheels's Avatar
It's hard to say for sure if you will rub or not. We don't recommend specs that aggressive, and your car is lowered, so there's a chance it could rub under compression for sure.
Old 02-06-2013, 04:19 PM   #11
2003 325i
My Ride: '03 Orient Blue 325i
I'd be willing to guess that under compression it will rub for sure in the back.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
