///M3 Forum
Old 02-06-2013, 09:44 AM   #1
M3dee
My Ride: 03 e46 m3
Traction control
Hey guys e46 m3, traction control keeps kicking in for no real reason any ideas? Wheel balancing? Wheel alignment?
M3dee is offline   Reply With Quote
Old 02-06-2013, 10:08 AM   #2
choxor
My Ride: JDM
I'd check tire pressure and tread wear first.
Old 02-06-2013, 11:48 AM   #3
Alan
Alan's Avatar
My Ride: 2006 M3
Loss of traction.
What does your tire tread look like? Tire pressure? New tires?
Alan is offline   Reply With Quote
Old 02-06-2013, 12:19 PM   #4
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
This
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-06-2013, 01:12 PM   #5
2002topasblueM3
My Ride: 2002 M3
If you have different tires sizes than the stock 225/45/18 front 255/40/18 rear setup, then that will do it too. If you have stock sizes, then what the other guys said, check tire pressure and tread wear. Plus this time of year the ground gets hard and tires don't heat up enough to be grippy like in the summer. So it's easy for the wheels to lose traction. Consider that too
2002topasblueM3 is offline   Reply With Quote
