Thread Tools Search this Thread Rating: Thread Rating: 37 votes, 4.89 average. Display Modes
Old 07-07-2013, 11:28 PM   #241
Commanderwiggin
My Ride: 900rwhp Turbo M3
Jake iirc Mert ran his 4.23s in one gear with a big shot of NOS and somewhere over 1000rwhp
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 07-07-2013, 11:31 PM   #242
JakeR
My Ride: 2006 M3
Sick, not necessarily doubting, just learning ...
JakeR is offline   Reply With Quote
Old 07-08-2013, 12:34 AM   #243
Twin_Turbo_S54
My Ride: M3
Jake,
I made 997 whp on Dynamics in 2009 this is like 1150 whp on dyno jet.
4 years of R&D passed and today my setup is improved.
on the 4,23 run I ve spayed a 100 shot and went through 1 gear. 3500-9000 rpm.
the area between 3500 till 5000 rpm was not powerful. needed nitrous.
today will go through 3 gears just like gtr35 where I will use 5700 + rpms. This is using the strongest parrts of the power band.
today I got automatic transmission which shifts so fast that you cannot identify gear shifts.
boost does not even drop 1 psi during gear shifts, stays solid.
all Wheel drive is programmable, at which road speed do you want it to be on?
how much torque do you want to transfer to the fronts?
So I am able to play around the all Wheel settings. thats a very very powerful tool.
on our road test with the XM3 a man came by the fuel station and asked about the air lifter.
he thought we were lifting front tires with an air lifter.
In fact the XM3 dead hooks and front tires almost lift off the ground.
Now working on this subject.
Jake, 5,2 to 5,6 seconds 60-130 is a sweat spot for a well prepared E46 M3.
to go below 5 is where the diffculties start.
to go below 4 is where you have to optimize the M3 seriously.
to go below 3,5 is where you have to master on M3, this is what I aim for.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 07-08-2013, 12:37 AM   #244
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Mert you really think you can get to under 3 seconds?
Gheybe is offline   Reply With Quote
Old 07-08-2013, 01:07 AM   #245
Twin_Turbo_S54
My Ride: M3
I do not know but I hope / work and pray each day. I pray God to enable me.
With all Wheel drive and automatic transmission 3,5 seconds is not difficult to attain.
To go sub 3,5 s more power will be needed.
To go 2,8-2,9 seconds, I need to push S54 B35 a lot.
well, there are good news.
when I went 4,23 s boost pressure was 32-33 psi.
I hear that big boys like big supras, and big gtrs are boosting 60 psi. Some of the supras go as high as 90 psi but this is not shared over public forums.
The supras rev 10.500 rpm as well..
I saw 60 psi on forums, but the 90 psi info came from a serious supplier
my plan is to raise boost from 33 psi to 45 psi and see what goes on.
If the system all together goes well, will test 50 psi.
55 psi
60 psi
65 psi and see what happens.
I may need to change turbochargers to boost 60 psi
So when I aim under 3 s, I did some calculations.
There is so much left in it.
btw keep 5 sets of S54 pistons on my shelf at my room. Ready for diasasters
To answer your question: I have dreams and plans and pray God each day to make my dreams come through.
Old 07-08-2013, 01:14 AM   #246
DavidDee
My Ride: 2004 325xi
Re: All Wheel Drive E46 M3
Wow... I cannot wait to see videos of this thing!
Sent from my SCH-I545 using BimmerApp mobile app
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 07-23-2013, 07:43 PM   #247
Twin_Turbo_S54
My Ride: M3
E46 M3 front fenders and hood installed on XM3.
Room for 245 tires.
Intercooler was taller, shortened the cooler as we are using methanol.
Some of the methanol cars do not even have an intercooler.
Old 07-24-2013, 11:37 AM   #248
JohnBlaze
My Ride: Black Sunshine
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 07-25-2013, 09:04 AM   #249
Soorena
My Ride: S1000RR
Good stuff Mert. You are likeable when you don't post junk.
Soorena is offline   Reply With Quote
Old 08-26-2013, 09:34 AM   #250
BMW E465
My Ride: 1dirty5
1 month bump
How's the car going Mert?
BMW E465 is offline   Reply With Quote
Old 08-26-2013, 01:12 PM   #251
Twin_Turbo_S54
My Ride: M3
I ve been working on E36 M3 Euro TT at the same time.
E36 M3 has small details and we stopped working on XM3 till we see 3,7- 3,8 s 60-130 with E36 M3 TT.
New 295 tires turned out to be much wider than Hoosier 295s..
New tires wont fit, decided to test 315 MT ET Street IIs.
road tests
August 21st posted here:
First road test of E36 M3 Euro TT
Tested new setup.
With very rich AFR 10,2-10,4 & 29 psi of boost pressure:
60-100 mph 1,87 seconds. We have very good traction.
My old 4,23 s 60-130 run had 2,40 s 60-100 mph time.
The new setup improved 60-100 mph by 0,53 s.
Tested new tires and 6 speed automatic transmission.
Sub 2 seconds 60-100 mph indicates 3,xx seconds 60-130.
Was not able to hit 130 mph, but old records show 1,75 s 100-130 mph.
Hope to see 60-130 mph in 1,87 + 1,75 = 3,62 seconds in the coming days.
100-190 km/h 3,07 seconds.
29 psi is "soft" boost, raise it 45 psi and test
Boost was 29 psi, a huge leak and 23 psi @8000 rpm.
The E36 M3 TT made us heavily focus on it as I the 1,87 s 60-100 mile time is an indication of sub 4 seconds 60-130 mph.
I hope to see 3,7 - 3,8 s 60-130 with my E36 M3 in 15 days and then put it on hold and road test XM3.
If RWD M3 will see sub 4 this means ALL WHEEL DRIVE M3 has to go sub 3 seconds 60-130...
Old 08-26-2013, 04:10 PM   #252
zurus
My Ride: Interlagos Blue Z4M
take some videos plz
zurus is offline   Reply With Quote
Old 08-26-2013, 07:48 PM   #253
MalibuMafiaV
My Ride: E60 M5 & Stg3 AudiS4
this!
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST GT35R
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 09-14-2013, 12:45 PM   #254
BDUB328I
My Ride: bmw 328i S54 sedan (
update? lets see some vids of some sub 3 sec 60-130!!
BDUB328I is offline   Reply With Quote
Old 09-14-2013, 02:22 PM   #255
Twin_Turbo_S54
My Ride: M3
We focussed on E36 M3 Euro TT for the last 45 days.
It cut a 1,87 s 60-100 mph time all day long. This time encourages me as it is a sign of sub 4 sec run.
Wanted to improve traction further, tested different tires, could not improve traction with the new tires.
Been testing various parts on this car. Cooling system is upgraded. Brakes are upgraded.......
Now our team is on holiday for two weeks. Once we come back from holiday we will try to get a 3,6-3,7 s 60-130 with the RWD E36 M3 Euro. We are just about to see these times
Regarding XM3, we put it aside to focus on E36 M3 TT.
I am very excited to test it as well. Plans are to road test All Wheel Drive M3 in November. In fact the day I see 3,6-3,7 s 60-130 mph with E36 M3, I ll start road testing XM3. It did hook very good on 225 tires as I stated before. Now wider rubber is on XM3 along with upgraded turbochargers.
Been testing launch control with pectel on XM3 as well. This does not take a long time, but needs practice and short tests. Despite the new bigger chargers I am able to build 12 psi at idle....
Regarding videos, bought a VBOX L***305;te camera system with 2 cameras.
It will Show the test and also the speedo, the boost pressure.
Add to that two more cameras of Chase Cam. In total 4 cams will capture these tests.
Old 09-15-2013, 08:39 AM   #256
BMW E465
My Ride: 1dirty5
So you finally have a vbox with cameras in your possession??
Woohoo, please make a new thread titled: Mert delivers the goods haha
Old 09-15-2013, 10:53 AM   #257
STORMER
My Ride: AA SC 98 M3
Ooooooh now this is getting interesting. Btw I have mentioned this before but I love your e36! I am excited to see some footage of these runs. You can officially become the king of forums and BMW. Whether anybody likes you or not! Lol
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 09-15-2013, 01:31 PM   #258
atrak
My Ride: 01' em three
thats ridiculous. 1.87 seconds on rwd. It does make me wonder if your getting 'great traction' on the rwd that awd will be similar based on driveline losses correct?
atrak is offline   Reply With Quote
Old 09-15-2013, 03:26 PM   #259
Twin_Turbo_S54
My Ride: M3
Its in Florida at my friend's house, 6 pallets full of parts waiting to be shipped to Turkey next week.
Video Vbox Lite has a 70 pages long manual, I am reading with pleasure.
I will never be a king, I am regular man who will die one day and till that day I will work like a slave on S50 B32s and S54s
These M3 engines, M3s are part of my life since 1997. I am addicted
Answers are unknown.
My E36 M3 Euro TT has been hooking "very good" since day 1.
On the other hand my E46 M3 Coupe TT has never hooked as good as my E36 M3.
Do I know the reason? To be honest NO. Thought about it, but could not find the answers.
E36 M3 cut 1,87 s 60-100 mph without extensive tests.
New set up & first test day we saw 1,87 s.
A new custom made E36 M3 coil over is in Florida, will be here 10 days later. The new coil over kit may help to improve traction.
Moreover, I have not played around traction control settings. I think I can play with the traction control settings and improve traction. Parameters need to be changed.
Moreover, Aeromotions wing is sitting on the shelf, wing will be tested as well, may improve traction.
Moreover, 1,87 s 60-100 was made on 3 year old tires, which saw at least 100heating cooling cycles. 4 different sets of tires are in Florida on pallet, will be tested, they may improve traction.
My dream / goal is to cut 1,6 s 60-100 mph with the RWD M3 all day long, not just 1 time, 20 times, 40 times. I think there is room for the E36 M3 to cut 1,6 s 60-100 mph.
All Wheel Drive M3 will be pushed more, by boosting higher / spraying n20.
XM3 has a 3500 cc 11,5 CR S54.
I do plan on using a 3700 cc S54 on XM3.
XM3 has higher drivetrain losses but also more power / more torque.
If all go well, XM3 should cut 1,3-1,4 s 60-100 mph. I need to test and see.
But if the overall all Wheel drive system Works, it should be faster than
E36 M3.
Time will tell, both M3s will be extensively tested before the end of year. For each of my M3s there is one Word document, i.e "XM3 PROGRAM". These documents are full of plans, parts to be produced, parts to get produced such as pistons and rods, spare parts in case of failure.... As we test each step, I put either a positive or negative sign next to it. E36 M3 TT, XM3 E46 M3 TT, E46 M3 T, E36 M3 TT dakar, four long documents....
Old 09-16-2013, 09:55 AM   #260
BDUB328I
Awesome, I'll b counting down the days til november
