E46 Xi Forum
Old 02-06-2013, 04:53 PM   #1
terdwrassler
My Ride: 2002 330XI
Replacing front driverside CV axle
The boot is busted and grease is everywhere and it's a loud click when turning. I got a replacement axle but I need to know about how long this swap should take on average. I'm renting a lift at a DIY place to get it done easier and I need a good idea of about how much time I should reserve. Anyone have a link to a DIY thread? I searched but couldn't find a thread specifically for that.
terdwrassler is offline   Reply With Quote
Old 02-06-2013, 05:06 PM   #2
Kubica
My Ride: 2003 325xi
terdwrassler,
It takes me 20 minutes with a lift and air to change an axle. Considering it took me 4 seconds to find the link below, I think you should budget about a month and a half.
Old 02-06-2013, 06:09 PM   #3
terdwrassler
My Ride: 2002 330XI
Kubica damn you are a funny guy, I'll confess it was mostly laziness but thanks for the link.
Old 02-07-2013, 11:51 AM   #4
latitude39
My Ride: 2002 325xi (163k)
Originally Posted by terdwrassler View Post
...I'm renting a lift at a DIY place ...
Which DIY place (in Denver) are you using?
latitude39 is offline   Reply With Quote
Old 02-07-2013, 12:16 PM   #5
terdwrassler
My Ride: 2002 330XI
The one in Westminster
Old 02-07-2013, 01:12 PM   #6
ixtoxi
My Ride: 02 330xi, 88 325iX
If all goes well, and it is your first axle, plan on 3 hours.
ixtoxi is offline   Reply With Quote
Old 02-07-2013, 02:10 PM   #7
Kubica
My Ride: 2003 325xi
Not with air on a lift!
Remove wheel, remove axle nut, remove strut pinch bolt and sway link nut, pop knuckle from strut, remove axle.
Oh and unbolt the headlight leveler from the control arm before anything else. And top up the diff fluid too.
Old 02-07-2013, 02:34 PM   #8
ixtoxi
Sheiss! Wish I had a lift!
Old 02-07-2013, 08:25 PM   #9
terdwrassler
My Ride: 2002 330XI
1 hour and even ran into a few issues, check out my old axle. http://imgur.com/pRObnHX http://www.imgur.com/kUTlGjO
Old 02-08-2013, 02:17 PM   #10
Sean McClellan
My Ride: 2004 325xi
Did you install a new axle seal? Hopefully you did while you were in there.
Sean McClellan is offline   Reply With Quote
Old 02-08-2013, 05:16 PM   #11
ixtoxi
Did mine last night, and it actually went much quicker than last time. About 1.5 hours total, which included cleaning up a lot of spattered grease.
Old 02-09-2013, 01:13 AM   #12
Kubica
My Ride: 2003 325xi
terdwrassler,
I've wrestled grumpies for more than an hour. Nice work.
Old 02-10-2013, 01:20 AM   #13
02Dinan330xi
My Ride: 2002 330xi 5spd
So glad i just found this post i plan to do this job to both sides as soon as this upstate New York snow is gone. Is this a proper brand to use or does any have a better recommendation? I always bought things from Bav auto when i had my e36 M3 but mainly because its all i knew. now that im on the boards i am realizing many people dont think quite as highly of them and have many other parts companys they use. Any and all advice is welcome. thank you
02Dinan330xi is offline   Reply With Quote
Old 02-12-2013, 10:47 PM   #14
02Dinan330xi
uhh. anyone?
Old 02-13-2013, 12:14 AM   #15
e46alfonso
My Ride: 330xi MT, mustang gt
Only use oem gkn axles from pelican parts or oembimmerparts. Replace the axle seal and it's also a good thing to replace all the nuts you are removing including the strut pinch bolt.
Many people here have broken strut pinch bolts so be careful with it. If that bolt takes too much force to loosen i guarantee you the head will snap.
Believe in yourself and you will get it done. You'll be fine as long as you dont break the strut bolt.
Old 02-13-2013, 11:32 PM   #16
02Dinan330xi
honestly man, i appreciate the input but i have 114,00 miles on my car and i really dont have 700 dollars to spend on 2 oem axles right now. there must be a better/more affordable option. Has anyone had any luck with other brands?
Old 02-14-2013, 12:21 AM   #17
e46alfonso
Tell me about it, the xi is a lot more expensive to maintain than a RWD car. We don't have that many options.
A1 cardone reman from napa auto parts are cheaper axles (about $100 each) but they leak diff fluid from the seal, at least my passanger side did. I had to replace the diff because it ran low on fluid. Maby you'll get lucky and yours won't leak.
Old 02-14-2013, 05:12 AM   #18
terdwrassler
My Ride: 2002 330XI
I honestly think you'd be fine with anything from these guys, http://www.rmeuropean.com/bmw-parts.aspx#Category
Old 02-14-2013, 09:05 AM   #19
miweber929
My Ride: 02 330xi
You might have more money for repairs if you didn't have to spend so much on stupid speeding tickets.......just saying......
Look around, OEM remans are worth it and can be found for $250 or so. You get what you pay for with these things; if you don't care then the $69 Napa or Rockauto ones are fine. They'll last a while, if you do your own swaps maybe they will last enough for you.
But if your stocks went 114k, how long do you think the cheap ones will go?
miweber929 is offline   Reply With Quote
Old 02-14-2013, 07:36 PM   #20
02Dinan330xi
Lol I hear u on the ticket. It's more on principle though and if didn't just delete that thread you could have seen my reply to that. Thank you tho
