Sponsored by BAVSOUND
Old 01-25-2011, 01:42 PM   #1
Str8down
My Ride: E46 M3
Dynavin Subwoofer out
Does anyone know if this rca output is pre-crossed over? If so, at what Hz?
Str8down is offline   Reply With Quote
Old 01-25-2011, 05:01 PM   #2
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Amazingly.......this has NEVER come up in all of the dynavin stuff here or anywhere else that I have seen!
I just tried it out on my test board and it it absolutely crossed over......Im going to go experiment a little bit to see if I can figure out at what frequency......
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 01-25-2011, 05:07 PM   #3
Str8down
My Ride: E46 M3
Excellent news. Will be great if we can figure out the frequency. But just knowing that it is crossed over is great, because now you don't have to get robbed of db's by using the low pass filter on the amp.
Old 01-25-2011, 05:11 PM   #4
J&T Distributing
My Ride: BMW
hhmmmmm.......from what I just heard in my quick test you will want to keep using a crossover.....I played around with it and from what I could tell it either has a real shallow slope or its crossed over real high.....like 150hz, Maybe even higher. Not all that useable.....
I didnt use any test equipment, just a quick test with my ears and the crossovers on my test amps to estimate the roll off, but it was high enough to give me my answer....
Old 05-17-2011, 01:36 PM   #5
m3evolution
My Ride: M3
Which would put out a stronger signal using the left rear and right rear rca output or using a rca y splitter from the single subwoofer rca out?
nvm I tried both and it sounds better using the sub line out
m3evolution is offline   Reply With Quote
Old 05-17-2011, 10:15 PM   #6
johnnySV
My Ride: AWDsprtwgn
does my dynavin v5 have a Subwoofer pre-amp output? considering sub install in the very near future... was assuming to use Rear Channel (non-sub) output.
If v5 has sub output then is Sub Level adjustable thru the head unit once installed?
johnnySV is offline   Reply With Quote
Old 05-18-2011, 03:46 PM   #7
Str8down
My Ride: E46 M3
Yes it has a Sub line out. No it isn't adjustable thru the head unit, why, I have no idea.
Old 05-18-2011, 07:10 PM   #8
johnnySV
My Ride: AWDsprtwgn
so then that being said..... i want to hookup a sub via RCA's to Dynavin v5 and my amp has built-in crossovers.... which set of Pre-amp Outputs from the DVN should I use and why ??
Old 05-19-2011, 09:02 AM   #9
Str8down
My Ride: E46 M3
While lack of sub control through the head unit sucks, I don't see any disadvantage to using the sub out. If you use the rear channel, you have to run a pair of wires as apposed to a single wire, and you would lose the rear channel if you ever decide to go with a separate amp for speakers. Not to mention then the sub would be subject to any F/R fading you may setup in your soundstage. So the short answer, use the sub line out.
Old 05-19-2011, 09:09 AM   #10
johnnySV
My Ride: AWDsprtwgn
i follow you on F/R fading and that's enuff of a reason for me to use the Sub Out.
thanks....
Old 08-25-2011, 08:40 AM   #11
JerzyBoy973
My Ride: 01 330ci
Gonna bump this thread instead of making a new one. But does anyone know pre-amp output voltage on the Dynavin units?
JerzyBoy973 is offline   Reply With Quote
Old 02-05-2013, 06:23 PM   #12
~evil_evooooo~
My Ride: M3
hey its 2013. but i am stuck with this same question. i want to use the line out sub. but i have left and right rca connector coming from the amp. should i use just one (L or R?) or use a y splitter?
~evil_evooooo~ is offline   Reply With Quote
Old 02-06-2013, 04:55 AM   #13
N4NOOK
My Ride: 323ci
Y splitter is fine.
N4NOOK is offline   Reply With Quote
