Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Old 02-07-2013, 02:37 AM   #1
alexis.torres
My Ride: none
Austin M owner's, ever thought of SMG swap to a true 6spd
@ Active Motorwerks can do the swap for you. They have the Autologic for the coding/re-flash.
http://www.bmwrepairsaustintx.com/
Once I was done with all the wrenching of the swap I plan to do the coding with NCS Expert after starting to use that program which I never used before, I found myself way over my head. So I started to searching for shops around Austin that can re-code my M and so I found them. So if anybody is interested in the swap you can PM me of give Mario a call @ (512) 428-5462
just tell them that Alex sent you
alexis.torres is offline   Reply With Quote
