Australia
Old 02-07-2013, 08:01 AM   #1
ating
My Ride: 2004 M3
Jack Stands
Hi guys,
Been looking for some jack stands. Can you tell me what you're using? I've been reading that the pin style ones are safer than the ratchet? I plan to use the costco (arcan) low profile hydraulic jack. I just need to get the jack stands sorted out.
Thanks!
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 02-07-2013, 01:35 PM   #2
Davconelectric
My Ride: 2 dog powered sled
ID:	489775 I'm using 6ton ratchet style off eBay. $88 delivered.
Davconelectric is offline   Reply With Quote
Old 02-07-2013, 04:01 PM   #3
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Do I smell a M3 rear end going in that space Dave?
E46 Coupe is offline   Reply With Quote
Old 02-07-2013, 04:08 PM   #4
Davconelectric
It stinks of m3
Old 02-07-2013, 06:40 PM   #5
CortinaD
My Ride: lots
I use the screw style alloy ones with the round pads and the ratchet ones only to hold up things like tailshaft etc as its easy to deploy with one hand. I also use race ramps for support if I have to get under it.
CortinaD is offline   Reply With Quote
Old 02-07-2013, 06:43 PM   #6
Jall
My Ride: 328Ci
I'm using 3tonne pin style from super cheap and 2tonne ratchet style from total tools.
Sent from my GT-I9300 using Bimmer App
Jall is offline   Reply With Quote
Old 02-07-2013, 06:58 PM   #7
ating
My Ride: 2004 M3
Thanks guys. So any ebay ones should be ok? I did read about some supercheapauto ones being recalled?
Old 02-08-2013, 08:09 PM   #8
SCE46
My Ride: M3
I had a scary experience with a super cheap trolley jack a long time ago. When I twisted the release valve to lower it the thread stripped and it dropped the car from full night. I'm very careful what I buy from there now.
BMW E46 M3
BMW E83 X3
BMW E46 Supercharged - Sold
BMW E30 SR20DET - Sold
SCE46 is offline   Reply With Quote
Old 02-08-2013, 08:33 PM   #9
ating
My Ride: 2004 M3
Yeah I don't wanna go cheap. I think the arcan hydraulic jack sounds good enough, just need to get the jack stands sorted. Most I see for sale are ratchet type tho, I thought the pin type are safer? Hmm...
Old 02-08-2013, 10:03 PM   #10
niiCk
My Ride: E90
The arcan hydraulic jack is awesome!
im using the pin type ones too..just make sure you get the flat top ones cause it'll ruin your jacking point pads if its the V-ish shaped lol
niiCk is offline   Reply With Quote
Old 02-10-2013, 05:12 PM   #11
TonyJ
My Ride: E46 330i
I bought the SCA 3T pin type when they were $30 a pair. Also bought the Trade Tools 2T trolley jack and stands for $128.
I used to have a cheap ebay 3 ton rachet. Piece of crap. The metal is so thin. It holds the car but I can hear it squeaking. The metal of the SCA and trade tools is much thicker and stronger.
TonyJ is offline   Reply With Quote
Old 02-10-2013, 05:17 PM   #12
TonyJ
My Ride: E46 330i
I also have problems with the 1400kg SCA trolley jack. It worked ok for a few month but then it failed to hold position. The jack will slowly creep down. Very scary when my finger was near there to adjust the jack stand position.
Old 02-10-2013, 05:21 PM   #13
TonyJ
My Ride: E46 330i
I never find a jack stand with a flat top. The closest is the SCA pin type which still has a shallow U shaped head. But there is an easy solution. Just cut a 6cmx3cm wood piece to snug fit into the jack point. The wood will sit on the u shap nicely and securely. Better than a complete flat head. Cheaper than a dedicated adapter.
Old 02-10-2013, 06:38 PM   #14
ating
My Ride: 2004 M3
I ended up buying these jack stands.
http://www.ebay.com.au/itm/CAR-JACK-...item5d3a1912b8
Flat top and pin type (looks like double pin). They look sturdy enough.
Also bought the arcan low profile 1.5T hydraulic jack.
