Old 02-07-2013, 09:50 AM   #1
Shlong
My Ride: 2000 325ci se coupe
In need of a air flow sensor.
Ive been looking everywhere for one and no luck. Unless I spend £300+ vat from bmw. Anyone know where to go or has anyone here have one? I've also tried the scrappys and where useless.
It's a 325 ci 2000 reg manual.
Shlong is offline   Reply With Quote
Old 02-07-2013, 10:20 AM   #2
WDE46
Weagle Weagle
WDE46's Avatar
My Ride: 2004 330Ci OBM
I believe there is a Hyundai sensor that is exactly the same as your 325. someone will know more specifics.
Old 02-07-2013, 10:24 AM   #3
TheJonRoss
My Ride: 2002 325xi, 2005 X5
ECStuning has this one: http://www.ecstuning.com/BMW-E46-325...sor/ES2091378/
I'm not familiar with the brand, and I'm always wary about third-party replacement parts (after a bad experience with a non-oe expansion tank and rad hose).
-Jon
BMWCCA# 473325
Join the Experience
TheJonRoss is online now   Reply With Quote
Old 02-07-2013, 11:24 AM   #4
WDE46
Weagle Weagle
WDE46's Avatar
I don't think I've ever heard anything good about MTC.
Old 02-07-2013, 11:27 AM   #5
rudycoop
My Ride: 3 pedal 330i
They are all over ebay cheap. I think it's definitely worth a shot at a cheap one to get you back on the road for now. I know some others will chime in against it, but I purchased one for 30 dollars brand new to see how it works and it works fine.
rudycoop is offline   Reply With Quote
Old 02-08-2013, 04:13 AM   #6
Shlong
Thanks for the replys guys. I have gone and ordered a non bmw part just to get on the road. Bloody problem after problem with this car. Never had so many problems with any other car that i have owned.
Thanks again.
Old 02-08-2013, 05:38 AM   #7
dmax
Stay stock my friends!
dmax's Avatar
My Ride: '99 328i 1.03809 mu
I hope it was your MAF and not just a common airleak...which is far more common when getting a mixture code than actually having a bad maf. Did you try unplugging your maf to see if things run better? If so, again, it usually then comes down to maf or air leak.
Good luck...and especially good luck with aftermarket electronic devices...usually they don't work so well...but I hope yours does. Let us know.
This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe."
The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax
Old 02-10-2013, 08:44 AM   #8
Shlong
Problem not solved. Still doing what is was with new maf. I have checked pipes and there all good. Not sure what else to do. Will plug computer in and reset all fault codes see if that helps. If not anyone else know why its kangarooing? Or what to check/change.
Cheers J
Old 02-10-2013, 08:50 AM   #9
Vertical_Flight
My Ride: '02 325i 5-spd Sedan
jfoj here on the foums has put together a huge wealth of information on this exact same issue....likely, your sufferings are caused by one or more items he addresses. Check out his post here, and let us know if it helps point you in the right direction! Best of luck!
Warum haßt du mich?
Last edited by Vertical_Flight; 02-10-2013 at 08:51 AM. Reason: Auto-save 1360507893
Vertical_Flight is offline   Reply With Quote
Old 02-10-2013, 08:55 AM   #10
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
MTC is pure GARBAGE.
VDO/Seimens is the only MAF you should be getting.
Old 02-10-2013, 01:09 PM   #11
Shlong
Thanks for that. Still reading it all. Will post once I've found out the problem.
