Old 02-07-2013, 11:14 AM   #1
wallythefish
My Ride: BMW E46
Water Pump 2000 reg BMW E46 318Ci Coupe
Huge help needed, I need to replace the water pump, however i have sheered of the "luggs" were you put in the bolts to prise it out, now i have tried wedgeing 2 crowbard to pull it out but it will not buge at all any suggestions, a friend of mine recons i will need a new engine is this the case any help will be appreciated.
Thanks in advance
wallythefish is offline   Reply With Quote
Old 02-08-2013, 09:30 AM   #2
wallythefish
My Ride: BMW E46
Anyone have any ideas at all???
Old 02-08-2013, 03:33 PM   #3
Sansho
My Ride: 2001 325i
Can you post a picture of the problem?
Sansho is offline   Reply With Quote
Old 02-09-2013, 10:12 AM   #4
markusmarkus
My Ride: 2001 330Ci
You can remove the water pump by screwing two bolts into the unused lugs o. The pump. Assuming you have the new pump on hand, you'll note that there are two threaded lugs on the pump. Find the appropriate bolts to remove the broken pump.
Old 02-09-2013, 12:20 PM   #5
wallythefish
My Ride: BMW E46
thanks
hi the lugs have sheered off its impossible to budge any more suggestions?
